Old 08-11-2016, 11:07 AM   #1
Rob Lloyd
Default A/FS 1989 Dodge Daytona 2.5 Turbo $4900
1989 Dodge Daytona C/S 2.5 Turbo Auto $5500 --> Dropped to $4900
- Engine built and blueprinted, 0.04” over, by Best Machine
- 3-bar MAP and big injectors with proper calibration running @ 20psi boost
- Recent compression check showed 120-130psi on all cyls
- A413 Trans built by John Donato, Cheetah RMVB, block/spring diff
- Very clean, no dirty street parts
- 8 gallon fuel cell and Bosch 044 high flow fuel pump
- 6-pt roll bar installed (rear seat delete)
- Sanders racing wheels with beadlocks (very light)
- 24.5” racing slicks (with spare set)
- Racing wire harness (all toggles on the dash, dash is gutted)
- ~2600lbs without driver (and ~75lbs ballast) A/FS weight
- Can hold more ballast in MPR-built ballast box to run B/FS weight
- This is a fully built race car, not simply a converted street car
- Fastest pass to date was 13.24 @ 100mph @ Columbus in good air
- Runs ~13.6 at B/FS weight
- Can easily be #1 qualifier at any track at B/FS weight
Check out the ad and pictures on RacingJunk
http://www.racingjunk.com/Stock-Supe....5-Turbo-.html
Rob Lloyd 3728 BF/S
Rob Lloyd is offline   Reply With Quote
Old 09-07-2016, 07:46 PM   #2
terrydye
Default Re: A/FS 1989 Dodge Daytona 2.5 Turbo
Looks like a great car at a great price, does the car fit in B/FS, if it des it is a Top10 qualifier. Where are you located?
thanks
terrydye is offline   Reply With Quote
Search this Thread:
Advanced Search
