I need to buy a better regulator, I have a 278/350 what one should I buy there are a lot on the market. i have a holley
thanks |
Liked 289 Times in 109 Posts
With the Super 10 I installed a Quick Fuel regulator. I do not recall the part number but will find it and post later.
Because of class rules, I installed a Quick fuel 585 replacement carb, with 175 fuel pump and QF recommended regulator. The entire systems has performed as expected with fuel pressure steady at all times. Some where in the pages of Super 10 build series you can find photos of those components |
#3 | |
Liked 800 Times in 237 Posts
http://www.quickfueltechnology.com/f...regulator.html Quick Fuel also makes that style regulator in a bypass model to bypass from the regulator back to the fuel cell. http://www.quickfueltechnology.com/f...regulator.html Lots of other good options out there, as well.
"That'll never work....." |
I have the 30-1803 regulator. It operates as expected, pleased with it's performance.
thank u very much
I just installed a Holley bypass regulator . I know it's a pain to run a return line the same as the supply . Even bigger is recommended . The fuel pump amperage is is less and more consistent and the pump is not dead heading . It also helps with fuel temp .
