Old 05-29-2016, 06:03 PM   #1
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Default 350/255HP Help please
Can anyone help me out a bit in knowing what my 350/255 stocker motor should be making for power and what rpm range it should be peaking at? I've been beating my head off the wall with this thing for a few years now and just dosen't want to get any better. I'm thinking I may have the wrong cam in it but really don't know where to turn next. Thanks.
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 05-29-2016, 08:26 PM   #2
Alan Nyhus
Liked 800 Times in 237 Posts
Default Re: 350/255HP Help please
Assuming no obvious issues, a couple of pulls on a dyno can save you lots of time.
What kind of h.p. numbers are you getting when calculating from the E.T.?
"That'll never work....."
Old 05-29-2016, 08:47 PM   #3
Chipper Chapman
Made 387 @ 5600 on A&J dyno. 100% new engine except for the cam as it was like new and only a couple seasons old. The worn out peice I had before made 384. The slide calculator agrees with this. A little background info, it's got all what's supposed to be great gear, .065 over cp c6 Pistons with total seal advantage ring pack, Manley rods, new heads from reputable shop that flow quite well, pac 1409x springs, bullet cam, short travel lifters etc.eal down is 8-9% cold, we've had it apart again to make sure nothing is going away or getting tight and all is well. It's just not adding up, and it's beginning to make my head hurt lol.
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 05-29-2016, 08:55 PM   #4
Kevin Panzino
Kevin Panzino's Avatar
Liked 778 Times in 142 Posts
Are you saying the leakdown is 8 to 9%????
Old 05-29-2016, 09:19 PM   #5
jamie2370
Liked 239 Times in 90 Posts
Not trying to be ugly but that combo should make north of 430. How "new" are pistons? Most likely the problem is the ring package. Having said that I am not an engine builder nor do I build my own motors but I have been around stock for all my life and fairly up to date with what it takes to make them run.
jamie2370 is offline   Reply With Quote
Old 05-29-2016, 09:28 PM   #6
HP HUNTER
Liked 373 Times in 129 Posts
Yes 430 + with much higher peak than 5600 RPM. 119 MPH @ 3350 = 440 HP
Old 05-29-2016, 09:32 PM   #7
Liked 1,923 Times in 432 Posts
You're down 35HP or more, and your peak is maybe 600RPM or more low.
If you're really leaking close to 10% on an engine that is up to 160 degrees, you're not sealed up.
I seriously doubt that either Total Seal or CP has missed the mark on the rings or pistons, especially if you had them work together. I've used their stuff successfully many times.
