Old 07-17-2007, 06:06 PM   #1
bill dedman
Liked 6 Times in 4 Posts
Default Legality of silicone hose???
I just put a 1/2" fuel line on my street/strip car. I was going to use aluminum, but when I went to buy fittings and hardware for it, I ended up at a chassis builder's facility called G.R.T. Race Cars, a company that apparently has a pretty good reputation, nationally, for building tube chassis, dirt track cars. They build complete cars for sale, so they fabricate everything, from the gound up.
The guys I talked to who worked there were "sold" on the high-tech silicone hose (fuel line) they use on all their race cars. It has 2,800-pounds-per-square-inch burst spec, and they said it is somewhat heat resistant (300 degrees, I believe he said), and they basically told me that it it will survive on a dirt track under the conditions of circle-track racing, it shoulr last forever on the street or drag strip.
I bought it when they told me that the push-on fittings they use require no clamp, and that they simply will tear the hose in two before one will pull off the barb.
It was a lot easier than putting all the bends in aluminum tubing... 'cause I had a LOT of plumbing to do. I am using two complete fuel systems; the original tank, and an 8-gal. fuel cell in the trunk, and two different pumps. Now, I am adding a bypass regulator to the system for more plumbing, yet.
My question is this: The 2007 NHRA Rule Book says that NHRA "Approved" silicone hose is legal. I need to know how to find out if this stuff I bought and installed is on the list. I don't think they put the list in the rulebook... or, did I miss it?
Any ideas on how to find out which hose is "approved"?
Thanks for any information or, comments...
Bill, in Conway, AR
Bill
bill dedman is offline   Reply With Quote
Old 07-17-2007, 06:33 PM   #2
Bill Harris
Liked 26 Times in 13 Posts
Default Re: Legality of silicone hose???
Pg 202 of the 2007 rule book under "Lines".
Bill Harris is offline   Reply With Quote
Old 07-17-2007, 11:48 PM   #3
bill dedman
Thanks, Bill. Found it!!!
Bill
