Liked 32 Times in 19 Posts
well my Jog was supposedly refreshed by a scam artist Motorcycle shop. I ran when I got it home but.... I got it out and it will start quickly but will idle for a short time and stall. Hard to restart if it does at all. Wait hours and it repeats and stalls. Will not allow to open throttle without dying.
I changed Fuel Pump and same thing. Any ideas? |
Liked 336 Times in 183 Posts
Check gas cap make sure vent is not plugged-- spark plug ---spark plug wire--- main jet plugged. --- battery good--Fed387
Liked 230 Times in 75 Posts
Have had the same kind of problem. Once mine will start and idle after a lot of kicking i let it warm up then it will rev up with out dying it is good for the rest of the day and starts easy every time. Mine is like ground hog day starts all over again. when mine wont idle i rip carb off and clean idle circuit out brake clean and compressed air. then back to ground hog day.
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 |
You make "rip the carb off" sound so easy. Mine appears buried in the frame. Do you pull the motor loose?
Liked 1,987 Times in 599 Posts
only run non ethanol fuel in your small engine equipment. I have 2 of the Chinese scooters and had nothing but problems similar to what you are experiencing. Started using non eth and no more problems. More and more gas stations are selling the non ethanol gasoline now.
Mike Pearson 2485 SS |
Liked 26 Times in 12 Posts
[QUOTE=Mike Pearson;501351]only run non ethanol fuel in your small engine equipment. I have 2 of the Chinese scooters and had nothing but problems similar to what you are experiencing. Started using non eth and no more problems. More and more gas stations are selling the non ethanol gasoline now.
Bingo |
