Liked 130 Times in 20 Posts
For Sale:
Parsons and Myers built 327 Super Stock engine. Can be run with 4gc carburetor as 1965 250hp engine, with a Holley as a 67 300 hp engine or with the Quadrajet carb as 1966 275 hp engine. Quick Fuel 585 carburetor Edelbrock intake by Heads Up Heads up heads (1 new head this past winter) Jesel shaft rockers Manley Valves Sheet metal valve covers 7/16 tapered push rods PAC valve springs Bowtie block .937 Jesel keyway lifters 50mm Roller cam bearings Comp Cams camshaft Jesel belt drive Diamond pistons Total seal piston rings Manley rods Honda journal Bullet cams built lightweight crankshaft Mallory front drive distributor ATI Balancer Aluminum kick out oil pan This engine is built with the best parts, is very reliable and went -.91 under (9.589 @ 136.98 in GT/E) in Charlotte at the points meet rd1 50 lbs heavy with regular oil. $15,900 Engine will be in my car at Charlotte nats, Indy pts, Atlanta nats, and Sport nats in BG coming up. Call text or email for more information. Thanks Brad (616)437-4958 brad@zaskowskibuilders.com
Brad Zaskowski 3697 STK, SS |
