Liked 101 Times in 27 Posts
On my stocker build the first outing went great but with one catch.......from run to run the fuel pressure may be up or down 2-3 pounds. This is a textbook Aeromotive bypass system A1000 pump with Aeromotive regulator and all textbook fuel line sizes to work with carbureted engine in this case a Q-Jet. Before I start throwing a regulator or pump at it COULD it be a bad carburetor function ???? May sound crazy but the carburetor does control resistance to pressure doesn't it ???? Help please.
NHRA AND IHRA STOCK ELIMINATOR 2772 |
Liked 56 Times in 27 Posts
Try a couple different makes of fuel pressure gauges & make sure you check it while the car is running ... Compare with fuel pressure @ 1000' on a pass...
Dave Ribeiro 1033 STK |
A little further clarification----there is no difference in gauges of Autometer on the cowl and Aeromotive at the carb, they are consistent with each other. The car can sit still for an hour or the next day and have a different pressure everytime it is started and can be higher or lower from where it was at the last run. ??????
Liked 210 Times in 47 Posts
fuel cell vented? Or had one system on a Superstocker that the fuel line had gotten sliced where the fitting was put in and the liner was getting sucked in when a lot of pressure was on and collapsing the line.
Took awhile to find that one and it was on a carb system. |
Liked 11 Times in 8 Posts
You have the same system I run, what about voltage? Have a way of monitoring it, pump output will change with varying voltage.Merely a guess as I've never had that issue using their products.
Joe Buchanan SS/BX 3117 |
Liked 536 Times in 110 Posts
X2, three very good areas to look at.
Jim Kaekel 3836 STK |
#7 | |
Liked 759 Times in 379 Posts
https://aeromotiveinc.com/fuel-press...blem-solution/ Last edited by 1320racer; 03-30-2016 at 07:32 PM. |
Liked 319 Times in 108 Posts
Had customer pulled his hair out over fuel pressure,would be 6-7lbs. then next thing you now would be 2-3lbs then back. changed regulators 3X,checked pump out,looked OK,he bought a new aeromotive just like he had,same thing. He found out line was sucking together between tank and pump, just took him 2 weeks to figure it out.
Mike Taylor 3601 |
