-gm mid deck block, 4.185 bore, 8.30 deck, keyed .937 lifter bores for splayed head, 283 mains, 55 mm roller cam bearing, jesel belt drive $2250
-book holley 4781 850 comp super stock legal- $600 STAINLESS SPLAYED VALVE V8 HEADERS, ADAPTER FLANGED BOLT PATTERN, BURNS 4-1 MERGE COLLECTOR, NHRA TETHERS, 1 7/8 INCH TO 2 INCH STEPPED, 25 INCH PRIMARY LENGTH. $650 1- TILTON SUPER STARTER SBC MINI TYPE #54-40001 1- EASTCOAST AUTO ELEC. STARTER SBC MINI TYPE 1- CSR STARTER DRIVER-SIDE MOUNT #100PDS 1- CSR REMOTE WATER PUMP 1- MALLORY SBC CRANK TRIGGER KIT 1- MSD SBC CRANK TRIGGER KIT 1- ATI 7 INCH ALUMINUM DAMPER 1.246 CRANK, 916980 ALU HUB, 916090 SHELL 1- JESEL DISTRIBUTOR DRIVE FOR .391 RAISED SBC 1- PETERSON FLIUD EXTERNAL WET-SUMP PUMP # PRO7A02C, 12 IN/ 10 OUT 1- PETERSON FLUID EXTERNAL PRESSURE REGULATOR 1- PETERSON FLUID INLINE PILTER 12 IN/ 10 OUT/ 3 GAUGE, 7 IN X 2.5 IN DIA. 1- PETERSON 2X1 MANIFOLD, 12 IN/ 2-10 OUT 1- PETERSON FLUID GILMER PULLEY # 06-0336, 36 TOOTH X 5/8 SHAFT X 1 INCH WIDE, LITE WEIGHT TYPE 1- CV PRODUCTS GILMER PULLEY # CVD11128, 28 TOOTH X 5/8 SHAFT X 1 INCH WIDE 1- GILMER PULLEY 28 TOOTH X 5/8 SHAFT X 1 INCH WIDE 1- COLEMAN GILMER CRANK PULLEY 1 INCH ID X 14 TOOTH X 1 INCH WIDE 1- GILMER CRANK PULLEY 1 INCH ID X 16 TOOTH X 1 INCH WIDE 315-542-1195 - kgotie@twcny.rr.com
Kevin Gotie Last edited by KG-CMF; 11-24-2015 at 08:54 PM. Reason: Deleted parts |
