Old 11-03-2015, 12:52 PM   #1
footbrakesbc
Default S10 Footbrake Build
I have a few questions about building s10 to bracket race in the foot brake class. I'm looking to run somewhere around 7.70s. Budget around $3500. I'm trying to enter the points next year at Fayetteville.
1. Will a 7.5 rear end hold up w/ mini spool and 4.56 gears?
2. Do I need to slide the springs over on the rear end or will a 8 inch tire be okay?
3. Should I go with a powerglide or th350?
4. Engine? 5.3 with a carb and cam change or 350 sbc with a little work?
As of now the s10 has the stock 2.8 in it. Only thing that has been done is I lowered it 3 inches in the back and changed the wheels to some iroc camaro wheels.
footbrakesbc is offline   Reply With Quote
Old 01-16-2016, 10:57 PM   #2
Kent
Kent's Avatar
Default Re: S10 Footbrake Build
I think I used a 28×12.5 et street which I think it's 9.7 or 10 wide without moving anything. I also used the stock rear with the gears welded and ran a best of 11.19 with those tires and rear with a 6.0 ls engine.
Kent is offline   Reply With Quote
Old 01-17-2016, 07:10 PM   #3
richie 2
Liked 205 Times in 93 Posts
350ci on a budget, tons of parts around. heads are most important...
Old 01-20-2016, 05:19 PM   #4
footbrakesbc
Kent how long did the rear end hold up w/ the 6.0? Did the 6.0 have any work done to it?
I was thinking a 6.0 with a cam would be good for 7.50-7.70. Don't want to put a cage in yet.
Old 01-20-2016, 05:36 PM   #5
Rick Blake
Rick Blake's Avatar
I would look for an 8.8 ford rear....junkyards are full of them and cheap...just a suggestion. Best of luck with your project, I am looking to do one very similar....please keep posting your progress
Rick Blake
Rick Blake 2395 SG, SC, SP
Rick Blake is offline   Reply With Quote
Old 01-23-2016, 11:29 AM   #6
Eman
Liked 133 Times in 76 Posts
With slicks the 7.5 rear will break, and it's not worth putting a penny into it. An 8.8Ford is a good choice and will stand anything you throw at it, but you will still have a C clip type axle and need C clip eliminators.
Turbo 350's are very available and need little money or mods to be good for what you're doing. I'd put a Transgo full manual kit in it and a hardened race for the intermediate sprag and you're good to go.
Old 02-07-2016, 10:46 PM   #7
NHRAFAN156
I have 2 sets of headers for sale for small swap into a S10 the cheaper set I will sell for $200.00 plus shipping
NHRAFAN156 is offline   Reply With Quote
