Old 09-02-2015, 09:14 PM   #1
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Default Innovate Motorsports Wide-band O2 Data System
Has anyone had any experience with the Innovate Motorsports line of Wide-band O2 sensor Data Systems? I'm looking to install a system in the 'wagon to be able to capture A/F-ratio's and other performance data as a tuning aid. The Innovate system seems to be both expandable and flexible enough to accomplish what I'm after, but I'd welcome any suggestions y'all may have on installation and ease of use.
Thanks in advance for your help!
Lew Silverman #2070
"The Wagon Master" N/SA
Old 09-02-2015, 10:17 PM   #2
Liked 1,953 Times in 439 Posts
Default Re: Innovate Motorsports Wide-band O2 Data System
Check your PM's.
Old 09-03-2015, 05:56 AM   #3
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
I have a Innovate LM-2. I would not buy another based on my experience. I've heard others mention Daytona Sensors. Please post what you find out.
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
Old 09-03-2015, 10:33 PM   #4
jakl
I also have the LM-2, and have been very happy with it. What problems have you experienced with yours? Who's wideband 02 would you recommend?
jakl is offline   Reply With Quote
Old 09-04-2015, 07:28 AM   #5
GallopinGhost
2 issues. One, it records about half the runs, it uses a SD card which I've replaced. Two, the RPM trace flat lines at 2K. I've hooked up the lead for the RPM to the coil, then to an injector. No difference. Innovates "fix" is to add a potentiometer to the lead, I've tried that several times. I haven't picked out another one yet.
Brian Carpenter
Stock 1358
Old 09-04-2015, 07:49 AM   #6
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,390 Times in 506 Posts
I am still using the older LM-1 to monitor one of the collectors and maybe once every 4-5 runs it loses RPM signal around midtrack but the O2 will still read. I thought maybe it was a bad ground or something. Frank Ferrucci helped me out with this unit and it has made a world of difference as I found a quick and consistent AF ratio with it.
'65 Mustang SS/L & L/SA
