Old 08-31-2015, 06:59 PM   #1
Bucket list racer
Default 69 Camaro new build
Looking at building a 350/255. Would like to know what stall and gears?
Bucket list racer is offline   Reply With Quote
Old 08-31-2015, 07:06 PM   #2
Richard Grant
Richard Grant's Avatar
Liked 13 Times in 7 Posts
Default Re: 69 Camaro new build
Run the 2.75 gear metric trans with 5.13 rear gears, 9x30 92.5 rollout tires are what I think most if not all 250/280 '69's are running. I hope this helps.
Richard Grant 4988 STK
Richard Grant is offline   Reply With Quote
Old 08-31-2015, 08:17 PM   #3
Bucket list racer
Thanks for the help.
Old 09-01-2015, 10:48 AM   #4
Geerhead55
Liked 5 Times in 5 Posts
Wink Re: 69 Camaro new build
You should post this, plus any photos in the classracer builds section so we can follow along on your project. Theres a lot of good overall information in there if you haven't checked it out already. I'd give ATI a call concerning your converter,, they'll get you very close to where you want to be right out of the box. Good luck with your Camaro.
Danny Durham
Old 09-02-2015, 11:38 AM   #5
Richard Grant
Good advice from Danny. PTC would also be a good choice. You need good info on your car before ordering the converter such as HP, gear ratio's, shifting RPM, etc. so that they can build you the right one for your combo. If you purchase a converter too early you will probably need to have it rebuilt when you get sorted out.
Old 09-02-2015, 04:33 PM   #6
Bucket list racer
Good idea. However I already have TCI TH350. Any ideas on how to make it work or should I be thinking about scrapping it and go another direction?
Old 09-02-2015, 05:03 PM   #7
Bucky, (that's your name, right?)
I'd say the best T350 , all aluminum, rollerized, low gear set, all the tricks,...would be about equal to a budget built T 200, so you can take it from there..
Old 09-02-2015, 06:18 PM   #8
James Perrone
Liked 1,867 Times in 436 Posts
Don't think so. I should know
james perrone 1290 STK
