Liked 288 Times in 109 Posts
Racers,
I am considering a high amp rated continuous duty solenoid as my master switch. Anyone have experience with doing this? In my situation it will be for weight saving reasons. I have the Super 10 on a weight reduction plan and removing the hardware that allows me to operate the cutoff switch while seated and from the rear will remove about 7 pounds. |
#2 | |
Liked 2,007 Times in 602 Posts
Mike Pearson 2485 SS |
#4 | |
I fully agree. KISS
Ed Wright 4156 SS/JA |
Liked 129 Times in 59 Posts
I'm guessing you have a battery(s) mounted in the bed on the S-10? Using a continuous-duty solenoid to replace a Cole-Hersey style master cut-off switch would require you to run power to a toggle-switch of some kind inside the cab of the truck, somewhat defeating the purpose of the master-switch disconnecting all power at the battery. Better to have one mechanical disconnect at the rear for safety's sake.
Lew Silverman #2070 "The Wagon Master" N/SA |
Liked 373 Times in 131 Posts
I could see it working with this type of rear starter solonoid system.
Might take a little more creative wiring than what is in the pic to work as "all kill" switch tho. ![]() Last edited by ALMACK; 07-27-2015 at 10:14 PM. |
Almack, I do not run an alternator.
