Old 03-06-2015, 01:02 PM   #1
Henry S
Liked 19 Times in 7 Posts
Default SS 5.3 ls combo
I was thinking of building a 5.3 LS rated at 305 for a super stock GT combination. It looks like I can use the 243 or 799 heads which I think can have flow numbers better than 300. My question is if this is a good combo to build and is the Throttle body large enough to support over 650 hp. I was thinking of putting it in a Nova for GT/GA at 3400lbs.
Any thoughts would be appreciated.
Henry Sliwinski
5774 SS/HA
Henry S is offline   Reply With Quote
Old 03-06-2015, 01:59 PM   #2
Jason
Liked 8 Times in 5 Posts
Default Re: SS 5.3 ls combo
What RWD car was the 5.3 LS installed in from the factory? And where is the 5.3 listed at 305 horsepower?
Jason is offline   Reply With Quote
Old 03-06-2015, 02:24 PM   #3
Henry S
I don't think there are any RWD cars but I was looking at the 2007 impala engine. Since aftermarket blocks are allowed could it not be used?
Old 03-06-2015, 02:26 PM   #4
Henry S
I don't think there are any RWD cars but I was looking at the 2007 impala engine. Since aftermarket blocks are allowed could it not be used? Sorry it is rated at 303 hp.
Old 03-06-2015, 05:55 PM   #5
Troy Henderson
Troy Henderson's Avatar
Liked 130 Times in 42 Posts
I've been wondering about this combination..
Troy Henderson
Henderson Race Shop LLC 816-520-5389
www.hendersonraceshop.com
Troy Henderson is offline   Reply With Quote
Old 03-06-2015, 06:41 PM   #6
JRyan
Liked 112 Times in 31 Posts
Don't know about the block situation. But the heads flow great. We've had a couple sets on the bench that we've done flow over 300cfm @.700 without getting really crazy with them with the stock size valves. Could be a pretty interesting combination I think.
Rick
Old 03-06-2015, 06:52 PM   #7
Bryan Broaddus
Liked 18 Times in 4 Posts
Removed
Bryan Broaddus 7568 STK ,SS
Bryan Broaddus is offline   Reply With Quote
Old 03-06-2015, 06:59 PM   #8
Henry S
I think the aftermarket block would be my choice on this build. and the heads have great potential. I am just not sure if the throttle body can support the airflow demands. Maybe a sheet metal intake can overcome the throttle body size. I would like to see the motor make between 680 to 700 hp. I think the heads can support that, the question is the other components. I think peak power may be in the 7800- 7900 range.
