Old 02-16-2015, 02:54 PM   #1
Wayne Scraba
Liked 186 Times in 48 Posts
Smile Garage Clean Out....bunch of new parts
American Racing Headers Fox Mustang Chevy LS3 & LS7 Swap-NEW!!!
Listed on Ebay - Click Link for Pix:
http://www.ebay.com/itm/291371077984
Brand new set of stainless steel ARH swap headers, new in the original box for Fox body Mustang with Chevy LS3 or LS7 swap. Headers have 1-7/8-inch primaries, optional 427 LS7 style head flange (full 3/8-inch thick -- fits LS3/L92 as well as LS7) and merge “hourglass” collectors (with scavenger setup). Includes street hookups and street hookup hardware. Beautifully built 304 stainless steel headers. Made in the USA (no Mexican or Chinese junk). No waiting and they’re ready to go! Regular price is $1375.
Buy It Now, They Have to Go!: $899.00!
Take an extra $50 off For Class Racer Member (total: $849)
________________________________________________
Big Block Chevy Lunati Voodoo Solid Lifter Cam, Lifter, Spring, Retainer & Lock Package – NEW!
http://www.ebay.com/itm/291339904257
Solid Lifter Voodoo Cam package for BBC Chevy. Includes the following components:
• Lunati 30110742 Chevrolet Big Block V8 396-454 1965-1996 Solid Flat Tappet Voodoo Camshaft RPM Range 2800 – 7000; Lift 0.610/0.625-inch; Duration@.050-inch: 249/257; LSA/IAC 110/106-degrees
• Lunati 70984-16 Solid Mechanical Lifters Chevrolet/GM V8 262-400, 396-454 (Center Oiling). These Lunati Solid/Mechanical Lifters are designed to meter the exact amount of oil for optimum performance while maintaining the precise lash needed to allow the camshaft to perform at its best. Lifter Diameter: .842-inch; Weight: 97grams;
Seat Height: 1.92-inch
• Lunati 74630K1 Signature Series Valve Spring Kit w/Titanium Retainers
Based around Lunati #74530 Signature Series Pacaloy Valve Springs.
• Pacaloy Springs: 74630-16; 1.500-inch OD; 0.816-inch ID; Seat Pressure: 145#@1.940-inch; Open Pressure: 423#@1.150; Coil Bind: 1.100-inch;
Retainers: 76729-16;
Locks: Valve Stem Size: 11/32"
Lock Angle: 10 Degree
Valve Groove Type: Single
Regular Price: $889.95
My Blow Out - Buy It Now Price: $699!!!
Take can extra $50 Off For Class Racer Member (total: $649.00)
__________________________________________________ __
Holley O-3310-C 750 CFM Vacuum Secondary Carburetor - NEW!
http://www.ebay.com/itm/291339904262
Brand new Holley 3310 (in the original box). Note: Includes at no charge, brand new, in the package Holley 20-13 Secondary Spring Kit and brand new in the box Holley 20-59 Quick Change Kit for secondary springs (total value of extras is over $35!).
Buy It Now: $320.00
Take can extra $20 Off For Class Racer Member (total: $300.00)
__________________________________________________ __________________________________________________ ________________________________________
Brand new Molnar 4-3/8" stroke BBC fully counterweighted Mark IV style; new along with a set of 6.490-c-to-c H-Beam Molnar rods. Setup works for a 572-582 in a short deck block. Really nice pieces.
Ebay Auction (no reserve; starts at $1111):
http://www.ebay.com/itm/291382916218
__________________________________________________ __________________________________________________ _________________________________________
Holley 12-801-1 Electric Fuel Pump (Red Label) 97 GPH – Brand New!
Holley Red electric fuel pumps feature an improved design for street and strip applications. Included is a new lower housing casting engineered for enhanced fuel flow, along with a tumble-polished billet look with the distinctive black logo. These pumps have a 97 gph flow rate (free flow), only draw 2 amps, and have a maximum pressure of 97 psi with an externally accessible pressure relief valve. Provides constant fuel flow without pulsation. Pump has 3/8-inch NPT inlets and outlets. It weighs only 2.88 pounds and include a mounting bracket.
Brand new in the Original Holley Box. My price: $104
Pix here: http://www.ebay.com/itm/301516929563
Holley 12-815-1 Electric Fuel Pump (Black Label) 140 GPH – Brand New!
Holley Black electric fuel pumps feature an improved design for street and strip applications. Included is a new lower housing casting engineered for enhanced fuel flow, along with a tumble-polished billet look with the distinctive black logo. These pumps have a 140 gph flow rate (free flow), only draw 4 amps, and have a maximum pressure of 14 psi with an externally accessible pressure relief valve. Provides constant fuel flow without pulsation. Pump has 3/8-inch NPT inlets and outlets. It weighs only 3 pounds and include a mounting bracket. Holley Black electric fuel pumps are compatible with alcohol or methanol fuels.
Brand new in the Original Holley Box. My price: $165
Pix here: http://www.ebay.com/itm/301516924604
__________________________________________________ __________________________________________________ __________________________________________
Holley #12-150 Electric Fuel Pump – 150 GPH
The exclusive gerotor gearset is engineered to quietly and efficiently pump fuel without the noise produced by conventional vane pumps. The chrome motor and black powder coated bracket match the mil-spec hard-anodized base for great looks and durability. While these pumps have the capability to feed stout race engines, they are equally at home on the street because of their design and construction techniques. These pumps set new industry standards for appearance and design while providing maximum pumping efficiency.
Features include:
* Gerotor design for quiet, smooth operation and durability
* Black Mil-spec nickel PTFE hard anodized billet base
* Show quality chrome 12V motor
* Profiled, black powder coated mounting bracket
* Laser engraved Holley logo and inlet / outlet designations
* 3/8 in. NPT inlet and outlet fittings
* Flows 150 GPH free flow (140 GPH @ 7 PSI)
* Supports up to 900 HP (gasoline)
* Includes a Holley #12-803 fuel pressure regulator.
Brand new pump and fuel pressure regulator in the original Holley Package. Price: $219
Pix here: http://www.ebay.com/itm/301516914945
Holley 12-454-40 Ultra HP Big Block Chevy Mechanical Fuel Pump – 200+ GPH
Big Block Chevy Ultra HP Billet Mechanical Fuel Pump
Constructed from CNC-machined 6061-T6 aluminum and hard coat anodized for corrosion resistance, these Holley Ultra HP billet mechanical fuel pumps provide the ultimate in strength and performance. Produces 200+ Gallons Per Hour (up to 225 GPH!). In These Ultra fuel pumps are put through extensive durability testing to ensure you an ultra rock-solid, long-lasting fuel pump. Originally intended for use on big block Chevy marine engines, these Ultra HP pumps are rebuildable and have bases that rotate independently from the top for ease of plumbing. Pump can be used in street-strip applications too. Pre-set at 10-11 PSI. Requires a fuel pressure regulator.
This is one of the highest performance mechanical fuel pumps available today!
My price: $469 (OBO)
Some pix on my Ebay listing:
http://www.ebay.com/itm/291373839113
__________________________________________________ __________________________________________________ __________________________________________________ __________________________________________________ __________________________________________________
I have a bunch more stuff I'm clearing out of here:
http://stores.ebay.com/Chevy-Muscle-...Race-Car-Parts
PM Me for more info if needed...
Wayne Scraba is offline   Reply With Quote
Search this Thread:
Advanced Search
