Old 02-12-2015, 09:29 AM   #1
BA1927
BA1927's Avatar
Liked 26 Times in 10 Posts
Default Help me clean out our garage
GARAGE SALE SICK OF WALKING OVER/AROUND THESE PART'S:
(2) USED WELD PRO-STAR 15x3.5 SPINDLE MOUNT WHEEL'S WITH ALL HARDWARE $225
(1) NEW IN THE BOX WELD PRO-STAR 15x3.5 SPINDLE MOUNT W/HARDWARE $200
(1) NEW WELD PRO-STAR 15x14 (6.5 B.S. 5x4.5 B.C. FORD/MOPAR) $250 WILL SELL
(1) USED WELD PRO-STAR 15x14 (6.5 B.S. 5x4.5 B.C. FORD/MOPAR) $150 BOTH $350
(2) NEW 1 7/8" HEADER COLLECTOR'S $40 ----
(2) USED DYNAMAX COLLECTOR MUFFLERS 2" PRIMARY TUBE HPC COATED W/EVAC BUNG'S $225 ----
(3) NEW BORLA SS COLLECTOR MUFFLER (40728) 2 1/4" PRIMARY TUBE $275 ea orW/Deal for 2 ----
(2) USED CHASSIS ENGINERING REAR COIL/OVERS W/O SPRING'S (15 1/2" OPEN 11 1/2" CLOSED) $125 ----
(1) POLISHED PG TRANS SHIELD OUT OF SFI DATE $50 ----
(1) CSI FLEXPLATE SHIELD WITH ALL THE HARDWARE OUT OF DATE BUT IT CAN BE RE-CERTIFIED $45 -
(1) CSI P.G.SUPERSHIELD WITH ALL THE HARDWARE
(1) NEW MOPAR PERFORMANCE PINION SNUBBER FOR AN 8 3/4" REAR $50 ----
(1 SET) BBC 4 BOLT MAIN CAP'S AND BOLT'S $100 ----
COMPLETE 8 1/4 REAR DRUM to DRUM W/4:45 GEARS AND SPOOL UNBREAKABLE AXLES MEASURE'S 54 3/4" BACKING PLATE to BACKING PLATE --- CENTER PIN to CENTER PIN 43" --
(1) SB CHRYSLER LAKEWOOD BLOWSHIELD BELL W/CLUTCH FORK - ZBAR & BLOCK SAVER PLATE $150---
(2) TWO 15x8 WELD PRO-STAR WHEELS 5x4 3/4 BC WITH 4 1/2 BS - W/HOOSIER 9x30x15 STOCKER SLICK'S THAT ARE TIRED $350 -
(2) WELD ALUMA STAR's 15x12 - 4 1/2" BC W/WO M/T ET STREET RADIAL SLICK's 31x13.50x15 (DOT SLICK's) NEVER ON THE TRACK
(4) WELD PRO STAR WHEEL'S 2 --- 15X14 WHEELS W/3" BS AND A 5on 4 1/2" BOLT CIRCLE HAVE BIG PRO/STREET TIRE'S MOUNTED --- 2--14x6 WELD PRO STAR'S W/STREET TIRE'S WERE MOUNTED ON MY PRO-STREET ROADSTER
(1) NIB PRECISION GEAR 4:10 RING/PINION FOR GM 7.5 (MONTE CARLO CUTLASS etc)
$125
(1) MALLORY DUAL POINT TACH DRIVE DISTRIBUTOR #2664501 (USED) $250
(1) MALLORY UNI LITE CHEVROLET DISTRIBUTOR (USED) $250
(1) TCI 6" ALL ALUMINUM BB CHEVY BALANCER $100 (RED ANODISED)
(15) SMALL BLOCK CHRYSLER (318-340-360) ADJ ROCKER ARM's/SHAFT's(USED) $130
(16) BIG BLOCK CHEVROLET ROLLER LIFTER's W/LINK BAR's $250
(1) JONES MECHANICAL TACH & CABLE
(4-5) ASSORTED FORD TOP LOADSER CLUTCH DISC AND PRESSURE PLATE'S
CALL 508-TWO SIX NINE-9611 MORE TO COME
DRAG RACE - STREET RACE - HI PERFORMANCE - MOPAR - FORD - HOT ROD - PRO/STREET - PRO STREET - SUPER GAS - NHRA - IHRA
BA1927 is offline   Reply With Quote
Old 02-12-2015, 04:18 PM   #2
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Re: Help me clean out our garage
on the 1 7/8 collectors. How big is the outlet ? (IE 3, 3 1/2) Are they new or used?
Old 02-12-2015, 05:29 PM   #3
mykids
Liked 2 Times in 1 Post
3 1/2"
mykids is offline   Reply With Quote
Search this Thread:
Advanced Search
