Old 02-05-2015, 02:18 PM   #1
hardtimes
Default Help with a converter
If your converter flashes 5200 with a 4.33 gear and you swapped to a 4.71 how much would that tighten the converter up.
hardtimes is offline   Reply With Quote
Old 02-05-2015, 03:30 PM   #2
Liked 5,137 Times in 1,960 Posts
Default Re: Help with a converter
Technically zero. Static flash stall would be the same, but I know what you mean.
It MAY act a bit tighter off the line, but how much? Some ..maybe
Anybody that tells you more specifically than that is just guessing.
Old 02-06-2015, 12:28 AM   #3
Adger Smith
Liked 880 Times in 311 Posts
What Mark is saying is converters react to load. Static is always static, but at the initial car move the load on the converter is different due to the gear multiplication. It is more apparent with gear changes in the tranny than rear gear changes. Too many variables to guess. That is what data logging and testing is for. If you change the gear and don't pick up it might not be the gear ratio that doesn't work. It might be the converter doesn't like the less load of the steeper gear. Talk to "Your" converter guy. He should know how your converter is built and should be able to give you a SWAG....
Adger Smith (Former SS)
Old 02-06-2015, 10:04 AM   #4
hardtimes
Let we ask another question. If you have a converter and it is to loose for your combo, and your put the right converter in.
Would your 60ft pick up or slow down.
Old 02-06-2015, 12:28 PM   #5
If by the right converter , you mean it flashes right around peak torque, then yes, it should pick up some ET.
That is with everything else being up to snuff...Suspension, carburetion, etc.
Old 02-06-2015, 01:59 PM   #6
Jim Bailey
Liked 584 Times in 94 Posts
Cool Re: Help with a converter
Hardtimes: exactly why I quit worrying about 60' times years ago. ....My car will 60' like crazy when the convertors too loose. I set my cars up using 330' times. - JB -
Jim Bailey is offline   Reply With Quote
Old 02-10-2015, 11:43 PM   #7
ATI Performance Products
Sponsor
ATI Performance Products's Avatar
Liked 9 Times in 1 Post
We have found in our own testing with the Challenger that each rear gear ratio change is roughly 150 rpm, when all else remains equal. So you could be as much as 300 tighter.
ATI Racing
ATI Performance Products is offline   Reply With Quote
Old 02-11-2015, 02:23 PM   #8
Todd Hoven
Guest
Posts: n/a
I changed converters in the same day on back to back runs. The quicker one showed nothing gained in the 60ft. It was all down track. In fact the car pitch rotated less off the line and showed less Gforce on the Racepak on launch. Food for thought. The race is not to the 60ft😃
