Old 12-23-2014, 01:54 PM   #1
jatmobkar
Default Bbc cast iron intake questions
I'm not class racing I'm just trying to go fast with stock parts. I have a 427/390 up intake on my 454. Has anyone modified the plenum to look like an aftermarket intake? Also would like info on carb spacers with a stock intake. I already had a dean oliver quadrajet and the car runs great I'm just looking to go faster. Thanks
jatmobkar is offline   Reply With Quote
Old 12-23-2014, 07:37 PM   #2
Terry Cain
Terry Cain's Avatar
Liked 232 Times in 108 Posts
Default Re: Bbc cast iron intake questions
You don't say what type of car but, if it's not a corvette (hood clearance) get an after market intake. I run the 427/390 Corvette manifold (aluminum) because I have to and it is a piece of junk.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 12-23-2014, 08:12 PM   #3
jatmobkar
I didn't know the stock stuff was that bad. How would it compare to a performer if the plenum was modified.
Old 12-25-2014, 01:56 PM   #4
Terry Cain
Terry Cain's Avatar
Haven't run an aftermarket on this car but usually they're good for 20 hp.
Terry Cain ???? STK
Old 12-25-2014, 03:34 PM   #5
Don't hack on the stock manifold, it just isn't worth the time or effort. Besides, hacking on the plenum could result in horrific mixture distribution problems, that could result in engine damage.
Just get the Edelbrock 7164 or 7561, and be done with it, you'll be time and money ahead.
We're not allowed to run spacers on stock intakes, so I doubt you'll see any data here for that either. But if you just bolt on one of the Edelbrock intakes, it won't matter, you won't need a spacer.
Old 12-25-2014, 08:22 PM   #6
jatmobkar
Thank you guys. I appreciate the help
Old 12-26-2014, 12:16 AM   #7
Glenn Briglio
Glenn Briglio's Avatar
Liked 986 Times in 314 Posts
Wink Re: Bbc cast iron intake questions
Edelbrock performer rpm and performer rpm air gap are good manifolds to use over cast iron oem manifolds. Putting a 4 hole spacer on top of them will also help if you have the room. If you have to use the oem manifold it can be modified to work better than stock.
Old 12-26-2014, 09:06 AM   #8
jatmobkar
Well that's what I'm wondering. What's the way to improve a stock manifold. Cliff Ruggles swears by the stock Pontiac manifolds. I know it might be apples to oranges but they can't be that different. I see the Pontiac guys grinding on the cast iron a lot.
