Liked 118 Times in 41 Posts
I have a 72 Mustang Fastback. It's a Q code Cobra Jet car but the 351 is toast.I have a 302 and C4 that I could put in the car. what class would it run in? Would it be good to build this car?
Liked 26 Times in 13 Posts
That probably isn't going to work. The 302 is a 2BBL NHRA rated at 143 HP. The weight break is 21.43 lb/HP but that will put you in U/SA at the 20 lb/HP category. In order to make the lower end of the class you would have to weigh 3030 lbs. It would be very hard to get a 72 Fastback that light.
It is interesting that the 302 had its HP refactored in August 2013. I don't know what it was previously or why it was changed. It was probably a competitor request to lower the HP, but maybe someone is actually running that combo. I have never seen one. Keep in mind that there is virtually no difference between the 71 and 72 so you could run it as a 71 Fastback or Mach1 and look at those engine combinations too. If you want to run it as a '71 429CJ/SCJ, let me know. I have everything you need.....
Bill Harris ex 2172 STK ex 2272 S/S |
Liked 20 Times in 9 Posts
Go ahead and get that Cleveland engine built to run stock in e or f we need more Cleveland stocker on the west coast I believe it's only 2 that I know of.If you need some help let me know.
7015 E/SA Sooner Storm |
Liked 240 Times in 112 Posts
Sooner, I'll throw my hat in the Cleveland ring, except it's not "under" yet & it's the 2bbl. version. Since Youngblood went to the dark side, I can't think of any other 351C's up here in D6. Are the 2 you speak of in D7 ?
Dave Noll, EF/S ,?/SA 6526 |
I was hoping for a budget build. Isnt a cleveland big bucks to build? At least i have the carb and intake already.
Me and Steve in d-7 and there is another but he hasn't bought it out as of yet.
So what exactly is the definition of "toast"? Is it completely blown up, like a rod through the block or does it just need a full rebuild? Does it have the correct heads, intake and carb?
Might be a little over stated. The car sat for 15 years before I got it. It's .030 over and 2 of the cyl's were rusted tight. I had to gently beat the pistons out. LOL. It might clean up O/S but not sure yet. Heads , intake, and carb are all 72. It's also a 2 bolt main block.
Looks like the reason it was parked is 2 of the cam lobes are round...LOL Last edited by RobbieRacer; 08-05-2014 at 01:20 PM. |
Well take that pup over to the machine shop and find out if it can be saved.Not all of the E and F cars on the west coast are super fast.Plus you don't have to have a aluminum intake you can still use a square bore intake and QF holley it will just be heavy.
There is also the D1ZE-BB intake that can be used with the Motorcraft spreadbore. It measure's big. I ran one in bracket's & it did OK but not sure how it would work on a stocker.
