Old 06-25-2014, 08:46 AM   #1
cad
cad's Avatar
Liked 93 Times in 52 Posts
Default 67 Camaro 396 alum hd- front end weight?
A friend has a 67 Camaro with a big block, alum heads, no ac, no ps.
He is ordering front drag coil springs and doesnt have access to scales.
Any idea what the typical front end weight is?
Thanks
Clark
Old 06-25-2014, 11:41 AM   #2
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: 67 Camaro 396 alum hd- front end weight?
Ours with an all iron 350 is 1604 pounds if that is of any help.
Rich Taylor
I/SA - 321
Old 06-25-2014, 01:08 PM   #3
cad
cad's Avatar
I know what mine weighs with my SBC and alum heads per the scales. Still need a BBC/Alum head weight.
Old 06-25-2014, 02:44 PM   #4
HandOverFist
My guess would be 1700 - 1750 pounds depending on the intake used.
Rich Taylor
I/SA - 321
Old 06-30-2014, 02:11 PM   #5
Jim Hanig
Liked 99 Times in 49 Posts
THE ALUIM HEADED rat motor should weight almost the same as a small blk with iron heads.
Old 06-30-2014, 03:39 PM   #6
FED 387
Liked 336 Times in 183 Posts
alum head bbc about 610---steel head 685---
Old 07-01-2014, 08:13 AM   #7
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Jim, when I switched my '67 from Z28 configuration to SS 396 configuration, the car picked up about 220 lbs. That was with iron heads. Aluminum heads are about 75 lbs lighter. I also switched from factory 4-piston disc brakes to drum brakes (-40 lbs.), but added the SS hood (+20 lbs.).
