Old 06-11-2014, 09:49 AM   #1
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Default Msd digital distributor
Just went thur the catalog and notice they make a digital distributor with adjustment inside the distributor anyone used this type before good are bad.They or saying drop it in hook 3 wires and adjust timing with something inside the distributor and it has about 9 other things that can be adjusted inside the distributor.
7015 E/SA Sooner Storm
astikhossw is offline   Reply With Quote
Old 06-11-2014, 10:28 AM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: Msd digital distributor
Part number please.
Dale
Dale Shearon
68 Mustang 6394
Old 06-11-2014, 10:43 AM   #3
astikhossw
astikhossw's Avatar
Looks like in the summit book msd 8394 Chevy,msd 8503 ford,msd 8504 Chrysler it even has a rotary dial for rev limiter to 10000 rpm
Old 06-11-2014, 11:30 AM   #4
FireSale
FireSale's Avatar
I don't have one, but it looks like they took the advance circuitry out of a digital control box and put it in the distributor cap. Click wheels in an engine mounted distributor cap might be problematic in a rough idle engine. A box would be easier to service and repair.
Dale
Dale Shearon
68 Mustang 6394
Old 06-11-2014, 02:49 PM   #5
SSDiv6
I believe in keeping the ignition system as simple as possible.
Adding so much electronics inside the distributor itself will make troubleshooting more difficult. Also, the distributor itself, its exposed to a lot of heat and harmonics from the engine. This increases the prospects of a failure.
Old 07-01-2014, 01:29 PM   #6
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
I think the concerns mentioned here make sense, but I have been using one of these for quite a while on my bracket car, and it's worked out great for me. I do wish it had a rev limiter that's easier to set precisely though.
I wound up using the lock-out timing; something like 15 degrees cranking, then locked in at 40 after it starts.
Dave Muller is offline   Reply With Quote
Old 07-02-2014, 10:49 PM   #7
6mmgunship
6mmgunship's Avatar
The Dist your talking about is basically a HEI module that has 7.5 amps output with the coil being remotely located. The module does not have the TCD circuit in it. I have some customers that bought this unit with the intent of running it stand alone. But found that with their motor program they needed to add a MSD 6al, MSD 6632 box etc to get what would extract the best effort out of the motor. It does allow you to pick different ramping curves for your timing.
Hope this helps.......
Pat Collins
6mmgunship is offline   Reply With Quote
