Liked 354 Times in 120 Posts
Sunoco gave Nhra a cool 1.2 million to become the official fuel for Nhra in 2015. Better than the 10 million that they give nascar. Right now they have no replacement for C25, I guess they wanted to slow down some of the cars. They also do not have nitro, only vp or Don Schumacher can get nitro into the states. Hope it all works out. Tom
Tom Meyer 5240 SS Stock ??? |
Liked 51 Times in 25 Posts
Saw on other sites VP and other brands still will be able to be run in Stock and Super Stock. Problem being if the VP doesn't pass only Sunoco will be available at the track.
I`m ok with it. I`ve never had a problem with Sunoco Purple passing fuel check.
Lane Weber It`s Not What You Drive That Wins....It`s How You Drive It |
Liked 229 Times in 71 Posts
I bet the price of sunoco will be going up!
They have to cover the million+ dollars they paid NHRA.
Ed Wright 4156 SS/JA |
Liked 174 Times in 39 Posts
I would think they already pay NASCAR more than they're paying NHRA.
3207 D/SA, C/ED |
I`ve never seen it go down!
Sunoco should be able to come up with whatever race fuel blends are needed. Renegade and all the other brands currently on the approved list will still be legal.
There are a number of sources for nitro, so that shouldn't be a concern. |
Here is the spec sheet on Vp X16 and Sunoco max
(Typical Values) Specific Gravity: .710 @ 60°F Lead: Yes Color: Red Motor Octane: 114 R+M/2: 116 Research Octane: 118 Reid Vapor Pressure: 6 psi Oxygen Content = None Technical Details Color Red Octane (R+M)/2 116 Research Octane 118 Motor Octane 114 Specific Gravity 0.712 Weight (lbs/gallon) 5.9 Reid Vapor Pressure 5.3 10% Evaporation 177 50% Evaporation 214 90% Evaporation 227 Stoichiometric Air/Fuel Ratio 15.2 Oxygen (weight%) 0 Ethanol (volume%) 0 HC Ratio 2.16 Lower Heating Value (Btu/Gallon) 111500 Lower Heating Value (Btu/Pound) 18900 Dielectric Constant -0.8 Leaded Yes Applications Oxidation Stability (min.) 1440+ Distillation:. 10% evap @ 155.7°F 50% evap @ 219.4°F 90% evap @ 254.3°F E.P @ 384.0°F Availability: Sealed Drums
Liked 186 Times in 55 Posts
Talked with a VP rep at the nationals at Maple Grove, he said that VP will be at all Divisional events.
Bob Lasko |
