Old 04-09-2014, 11:43 PM   #1
JoryE
JoryE's Avatar
Default Burnout Procedure with Proflite
Just wondering if anyone can offer up some tips/advice on burnout procedures they have had success with, and vice versa, with a three speed Proflite. Its our first season with the tranny and we want to make sure we keep it in one piece knowing they arent anywhere near as durable as our trusty old powerglide.
Cheers!
Jory Elliott
Northern Force Racing
SS/AM 155
JoryE is offline   Reply With Quote
Old 04-10-2014, 08:58 AM   #2
Jeff Teuton
Liked 325 Times in 50 Posts
Default Re: Burnout Procedure with Proflite
Make sure the tires are wet and hit the throttle in high gear. Or if you can manually shift 2-3, then get them to turn in 2nd and go to third and get some wheel speed. I assume you have a TH with 904 guts.
Jeff Teuton 4022 STK
Old 04-10-2014, 10:13 AM   #3
Michael Compton
Liked 59 Times in 13 Posts
I do exactly as Jeff says. Start in 2nd gear and shift into 3rd gear.
Michael Compton is offline   Reply With Quote
Old 04-10-2014, 10:20 AM   #4
Ed Wright
Ed Wright's Avatar
I do too, and get it in 3rd gear before letting it move forward out of the water.
Ed Wright 4156 SS/JA
Old 04-10-2014, 12:36 PM   #5
Rick Pike
I do my burnout as with the above racers and as originally recommended by Protrans, seems to work well. I'll add that I switched partially from a powerglide ten years ago and 100% five years ago and have NOT had a single failure. "Thanks Dave."
Rick Pike is offline   Reply With Quote
Old 04-10-2014, 03:00 PM   #6
JoryE
JoryE's Avatar
Thanks for the feedback everyone! The debate for us was between doing a third gear burnout compared to the 2-3 shift to prolong the lifespan of the trans. I think you've all made it pretty clear the 2-3 option is a viable one and likely what we'll go with.
Jeff, the trans is an A/MP Torqueflite configuration.
Cheers!
Jory Elliott
SS/AM 155
