Old 02-07-2014, 03:10 PM   #1
Doug Domm
Liked 85 Times in 22 Posts
Default VP to Sunoco reference
Is there a VP to Sunoco equivalency reference chart anywhere and typical tune changes between fuels?
Doug Domm is offline   Reply With Quote
Old 02-07-2014, 06:17 PM   #2
VanPelt
VanPelt's Avatar
Default Re: VP to Sunoco reference
http://www.smithtex.com/racing/fuelcomp.html
VanPelt is offline   Reply With Quote
Old 02-08-2014, 12:39 AM   #3
Doug Domm
Excellent reference chart. Thank you
Old 02-19-2014, 02:26 PM   #4
Mike Croley
Originally Posted by VanPelt View Post
I hadn't looked at that chart for years, but I went back and took a look at it today. It is very, very, very outdated. Many of the companies listed haven't been in business for years and in one case for over a decade.
For up to date and correct specs, go to each manufacturers web site, the specs change often.
Mike Croley is offline   Reply With Quote
Old 02-11-2014, 09:24 AM   #5
njk53
Is VP C-10 Leaded or Unleaded?
Nelson Kowal
Stock 345
Old 02-11-2014, 09:35 AM   #6
Rsmith38
Liked 28 Times in 15 Posts
C-10 is unleaded. (Now C-9 also unleaded)
Rsmith38 is offline   Reply With Quote
Old 02-12-2014, 10:44 AM   #7
njk53
Is there a leaded fuel with a lower octane (100 or less) out there that is NHRA Approved?
Nelson Kowal
Stock 345
Old 02-12-2014, 03:58 PM   #8
jmarkaudio
What you want to pay attention to is the SG and RVP of the different fuels. Similar specs on both will usually need similar jetting and perform close. If either deviate you will likely need to make changes. As far as lower octane than 100, what are you looking to lower octane for?
jmarkaudio is offline   Reply With Quote
Old 02-13-2014, 09:25 AM   #9
njk53
I have a 9:25.1 Compression Ratio Motor. It would run much more efficiently on a lower octane fuel than 110.
Nelson Kowal
Stock 345
