Liked 28 Times in 15 Posts
Is there a disadvantage or advantage to using a 1 piece rear seal crank? Found a 1 piece core 305 and wanted to use it in my car which was originally a 2 piece. Would an older 74 - 80 305 core be better?
Liked 205 Times in 93 Posts
whats the application?
83' 305, 416 head, ft piston, Camaro
Liked 129 Times in 59 Posts
As I understand it, the way the rules are now written for Stock, you have to use the original OEM crankshaft for the year and horsepower claimed for your vehicle. There are a few aftermarket blocks that are acceptable, at least for the SBC, but the original crankshaft has to fit.
I may be misinformed, but as it stands now, no late-model blocks and cranks in early-model chassis.
Lew Silverman #2070 "The Wagon Master" N/SA |
Liked 319 Times in 108 Posts
As far as I know could use 1pc or 2 pc seal block and be legal.
1 pc. uses different flex/flywheel is external balance on rear and has different bolt pattern. I have converted several to internal balance takes about 1'' heavy metal usaully depending on bobweight. the reason they are external balance on the rear is when flywheel flange is made round it loses that extra flange that is counterweight Mike Taylor 3601 |
Any comments on strength of the newer block and 1 piece seal crank? The engine is tore down to the short block, it had 187 heads on it. It's layin there and the price is right.
One piece rear main production blocks are junk if they have lots of miles on them. I have thrown away a few dozen blocks that would not clean up at .060 over. I have also found ones that would clean up at .060, but the wall was too thin on the thrust side. I am not trying to discourage the use these blocks, but a thorough inspection of the block is a must before even considering purchasing any parts. Two piece parts are easy to find, cheap and it is internally balanced. Whats not to like about that?
