Go Back   CLASS RACER FORUM > Class Racer Tech > Garage Tech
Old 08-19-2013, 01:34 PM   #1
Sean Marconette
Sean Marconette's Avatar
Liked 277 Times in 77 Posts
Default Garage floor drains
Finally getting ready to build my shop. Inspector is allowing me to install floor drains in shop but says I need an oil separator. I am piping floor drains to the side of building. So a separator will be outside of the shop and buried next to the building. Building is 40x65, and I can't imagine squeegeeing water from one end to the other, to get water out the garage door.
Has anyone fabricated something and if so, any ideas would be great. The inspector said a plastic 55 gallon barrel could be made to capture the water from the floor drains.
BTW I am on a septic system, and also do not want to contaminate it, or the ground.
Thanks
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 08-19-2013, 03:01 PM   #2
tj310
Default Re: Garage floor drains
Whatever makes the inspector happy ! Do you really plan on having water in all bays? I 'm just doing a floor now 32 x 54 and plan to have one drain to a sump pump. I hope to keep most of the floor dry and just sweep to clean. We are also on septic so it would mean doing a seprate system if I were to do a shower washroom at that point might be more concerned .---Trevor
Old 08-19-2013, 04:36 PM   #3
Painter
Liked 162 Times in 45 Posts
Have your floor poured as flat as possible. No drains, no pitch. Us a commercial mop and bucket. Can't build or set up race cars on a hill. Oil dry is criminal.
Painter is offline   Reply With Quote
Old 08-19-2013, 05:18 PM   #4
Sean Marconette
I might just do away with the floor drains all together then.
The building is all open. No bays. A bathroom, sink and the trailer dump drain tied into the septic system.
I was just thinking if I washed a vehicle, or when snow melts off a vehicle it would be nice to have it go to a drain.
Less work on the rough in this way!
Thanks for the info.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 08-20-2013, 12:04 PM   #5
CycloneFE
CycloneFE's Avatar
Liked 2 Times in 2 Posts
My inspector did not say I needed a seperator, but I could have a "holding tank" ie; septic tank with no laterals, pump out as needed.
Steve Jackson
Old 08-22-2013, 03:21 PM   #6
Rob Petrie E395
Liked 216 Times in 77 Posts
What I did is I poured the floors flat but I put a trough near the bay doors and I squeegee the water to them. I also put a trough at the end of the apron out front to direct the runoff away from the driveway. The discharge runs into my yard with no problems in the last 10 years. But I do not wash out oil based products.. Best thing I did for the floor was when I put a epoxy coating on it to make it easier to clean. Lowes sells the grates that I used on top to of the troughs to keep the floor smooth and not have to bounce over the trough when driving in and out.
