Old 11-18-2006, 03:37 PM   #1
Ron Miller
Liked 13 Times in 7 Posts
Default Product Engineering fuel system
Product Engineering Fuel Pump systems
Combo 460 Racing fuel pump kit: PE 4805 NEW Jobber: $615.00
1 ea. PE 4450 Combo Racing Fuel Pump, CNC Billet Aluminum body
1 ea. relay harness-PE 1050, 1 ea. inlet fitting #12 AN x 12 ST, 1 ea. outlet fitting #10 AN x 12 ST, 460+ Gallons per hour,supports up to 2000 H.P., Adjustable up to 43 PSI, Ext -8 AN bypass (Adj), Cleanable filter, Alcohol Compatible, Works w/ 12 & 16 volt systems, 7 vane imp, -12 AN boss O-ring in/out ports, Continuous duty pump dose not need a step down box, 2 Year Parts & Labor Warranty
4-Port Fuel Regulator with Bypass System: PE 9050-4P NEW Jobber:$366.00 For Carburetors and Nitrous Systems, Adjust from 3 - 12 PSI, #10 inlet has 2 #8 outlets for carb and 2 #6 outlets can used to feed Nos, Stainless steel needle/seat asy, CNC Billet Aluminum body, 2 Year Parts & Labor Warranty
Combo kit with 4-Port Regulator By-Pass Jobber:$981.00. Sell for $900.00 plus shipping, will except US Postal money order only.
This all ""NEW STUFF"", One of the Finest Fuel Systems out their.
Do you're fuel system right the first time, you can never have enough fuel volume or pressure.
Thanks for looking and the ad space,
Ron Miller
Brownstown,Michigan 48134
734-782-9333 before 9:00 pm
rmiller249@comcast.net
Ron Miller
3287 GT/DA 92 Camaro
Ron Miller is offline   Reply With Quote
Old 12-13-2006, 12:47 PM   #2
Ron Miller
Default
package still for sale
Ron Miller
Old 12-31-2006, 03:41 PM   #3
Ron Miller
Default
Package still for sale
Ron Miller
Search this Thread:
Advanced Search
