Liked 262 Times in 124 Posts
I've been doing needed updates to the old Fairlane. We built new headers 1 3/4 stepped to 1 7/8 there at Nitroplate getting coated. So while that's being done I thought I'd replace the 4 wheel (stock) drum brakes with strange 4 wheel disc. My question is what size bore master cylinder should I use? I asked the techs at strange and a friend that's done lots of dirt car brakes but got different answers from both of them. I also took the master cylinder off the car and measured the bore it was 1" and worked great with the drum brakes. Any help would be greatly appreciated
Liked 319 Times in 68 Posts
Ask Tom Goldman,nobody better.
Lee Valentine 1661 STK |
Liked 13 Times in 7 Posts
I would try the 1" before changing it. You can get a generic suggestion from the brake people but my experience is it takes trial and error to find what works best for you. There are a lot of ifs ands and buts, such as brake petal ratio, car weight, perfered petal feel, etc.
Richard Grant 4988 STK |
Thanks for the response's, yea I'll probably try the 1" MC. I had to pull it a part to check the bore size I suffer from CRS. I just don't want a peddle so hard I can't stop the car. Thanks Robbie
Liked 889 Times in 239 Posts
1" Might be a little small . It might work if the pedal ratio is low ,like 4-5 to1.like many power units use.
Robbie , I suspect your car was also manual brakes ,so the ratio is probably at least 6-7 to1. Since you will be using 4 piston calipers ,I'd use at least a 1 1/16", or even a 1 3/32" bore cylinder. You should be able to stop with normal pedal pressure. ...The smaller bore will give higher pressure with less effort, but it also makes it easier to lock the brakes when stabbing the pedal .
Tom Goldman 1500 SG , 1506 STK Last edited by Tom Goldman; 08-06-2013 at 08:26 AM. |
Liked 20 Times in 9 Posts
I have a 1984 t-bird that is 2500 lbs with driver and i have strange disc brakes on all 4 with a stock ford master cylinder and i can stab it once or twice at 129 slows down great nothing scary.I use 2 pistons front and 4 piston rear.
Your T-bird master cyl is 21mm or about 13/16".
It will work with 2 piston calipers, but would probably be undersized for a 4 piston front caliper. It also will work better with a low pedal , ratio like 4-1. If you're using the stock pedal and it had power brakes ,thats about what most of them are. Getting good brakes is all about balancing pressure with the correct volume ,while getting a comfortable feel for the pedal pressure required.
Tom thanks for the reply, Do you think it will stop ok with the 1" MC. I'm sure its a manual brake set up on the car from the factor.
Well Tom,I bled the brakes to day and I'm sure it would stop ok but I can't deal with the peddle feel. I'm going to put on a MC with a bigger bore to firm up the peddle. Tom I under stand Chrysler as a MC that's used in a lot of different cars I think its 1.125 bore would that be enough of a difference to feel?
It will work Robbie, but it will take more "leg" effort.
It's amazing how much difference a 32nd of an inch or two will make in pedal feel.
