Liked 20 Times in 15 Posts
if you had one tire, with 10" tread and mounted it on a 10" rim, and then mounted the same tire on an 8" rim...would the section width be wider on the 8" rim than on the 10" rim?
thanks Rod in AZ |
It would appear to buldge, but I don't see how it would be wider.
I don't think you will see any gain doing that. My stuff has always been faster on wider wheels. Let us know what yours likes.
Ed Wright 4156 SS/JA |
when a tire manufacturer gives a "section" width dimension on a tire that is the measurement of the tire through the sidewalls on a "spec" size wheel...so the wheel width as it gets wider than that will actually make the section width dimension larger and the opposite on a narrower wheel....
D L Rambo STK 1300 |
For my tiny tires (14 x 8 x 20) I have found (through multiple back to back to back tests) That a six inch wide wheel crosses the finish line 200 rpm's higher than an 8 inch wide wheel. It seems like the 8 inch wide wheel allows the tire to grow more.
Art Leong 2095 SS |
Liked 373 Times in 131 Posts
Overall width of the tire would be more with a wider wheel.
So, to answer the question, I would say the section width would de-crease with the 8 inch wheels.
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
