Old 06-14-2013, 04:05 PM   #1
Liked 5,137 Times in 1,960 Posts
Default Former Torque Converter...
This is what happens when you put a street and strip converter behind a 6-71 blown SBC in a Model A street rod. The sprag rollers were completely gone, which means the were ground up and went through the trans.
I was able to save the T350 but there was a lot of damage in the front half.
How this relates to to S/SS , is that I suspect the converter was ballooning, and the rear most bearing popped out of place an disintegrated .That allowed the stator to slap back and forth and punch out the inner race and rollers, causing them to bend all the fins over.
Believe it or not ,there are still some 8 " units out there that are built in the old school way.
Old 06-14-2013, 05:19 PM   #2
Billy Nees
Default Re: Former Torque Converter...
If that converter was ballooning, somebody better be checking the thrust bearing in that blown SBC!
Billy Nees 1188 STK, SS
Old 06-14-2013, 06:38 PM   #3
Good point, but the wear on the hub from the pump gear shows me that it had a lot of pull up,
but at this point we don't even know if it was 6.150 overall to start out..That might have saved the thrust.
Old 06-15-2013, 09:23 AM   #4
jims5600
Liked 21 Times in 9 Posts
Billy is spot on. Everytime we broke a converter in our comp small block the thrust bearing was garbage.
jims5600 is offline   Reply With Quote
Old 06-15-2013, 10:32 AM   #5
Stewart Way
Liked 70 Times in 22 Posts
Mark
This is why I try to read all the posts in this section. What Billy said makes sense and is logical if you think about it but I'm not sure I would have thought to check the thrust if that was my converter. A lot of good info in this section, now if I can just remember it after I sleep. Never had a converter go like that. How noisy is it when its chewing itself up?
Stewart Way 2424 SS
Old 06-15-2013, 03:51 PM   #6
Originally Posted by Stewart Way View Post
Mark
Stewart, The sprag rollers were completely gone..unrecognizable .
But before they disintegrated into the trans, they must have made a hell of a racket.
Old 06-15-2013, 03:56 PM   #7
What were you breaking?
Generally when a sprag breaks, it expands the stator, stretching the case.
When the hub bottoms in the pump, and the pilot bottoms in the crank, then you could have thrust problems.
That's not what happened here though.
