Old 05-18-2013, 02:33 PM   #1
art leong
Default Crankshaft harmonics?
Can crankshaft harmonics/vibrations cause anything to happen in the valve train?
Art Leong 2095 SS
Old 05-18-2013, 02:42 PM   #2
SSDiv6
Default Re: Crankshaft harmonics?
Yes it can.
Old 05-18-2013, 02:53 PM   #3
art leong
I'm wondering if harmonics had a hand in my rocker to valve wear.
That is another thing that seems to be specific to my motor. Others have run same cams and springs trouble free.
Art Leong 2095 SS
Old 05-18-2013, 03:09 PM   #4
SSDiv6
Art, although you have a timing belt, the harmonics and frequencies will transmit to the valvetrain due to the lack of dampening from a crankshaft that lacks counterweights.
I believe that a crankshaft with counterweights and the right harmonic balancer will solve a lot of your problems.
Old 05-18-2013, 05:25 PM   #5
art leong
Even though the crank checked fine I'm going to put in a stock crank. I don't believe 8 pounds will hurt me that much. And maybe I'll get rid of these "one of" problems.
My other motor with less cam, less compression, and a stock crank. Responded to rpm a lot better than this motor. It was half a second between bracket mode and race mode. This motor was only two and a half tenths. That's shifting 1000 rpms short and running taller tires.
It might go quicker with the stock crank.
Art Leong 2095 SS
Old 05-18-2013, 05:45 PM   #6
SSDiv6
Art, I believe you will not notice that much of a change in performance.
Nevertheless, if you want to get the best out of the crankshaft, I would suggest your crankshaft to have some weight removed and probably change the shape of the counterweight and have the lightening done properly.
My choice and recommendation is Shaft Tech:
http://www.shaftech.com/modification.html
