Was wondering when is it beneficial to use a merge style collector, and how do you go about picking your choke point
Are pipemax type programs accurate as far as sizing and taper of cones,or do you error smaller to be safe? Ive gotten some data from pipeamx but it seems the minimum choke is big in relation to some other combos ive seen Combo is as follows 4.070 bore 6.2 liter ALUMINUM HEADS AND BLOCK 4.0 stroke callies crank callies 6.125 h beam rods wiseco dome piston 14.9 compression 1.2-1.2-3mm low tension backut ring package GZ motorsports vacuum pump -12" or so for wet sump? 55 mm cam core 700"int-690" lift after lash 274*-280* at 050 in at 108 13.5 degree ls based 245cc runner tfs heads - cnc ported by TEA -and gone over a little by hand these flow 360-285CFM at 650" lift ," lift or so hollow stem 2.100 intake valve -stainless 1.6 exhaust MAST 2 PIECE CNC'D CAST 2 PIECE MANIFOLD Bigs `1050hp DOMINATOR on top of 1/2 SHEAR PLATE 1-7/8 headers TO- 3-1/2 EXH 2900 PD CAR 275 DRAG RADIAL 4.30 GEAR TH 400 8IN CONVERTER(6200-6400 FLASH) RACED IN DENVER AT 7500-9500 FT OF D/A IN NORMAL SUMMER CONDITIONS PEAK, POWER RPM WANTED AT 7500 OR SO My concern was also that the old collectors may be a touch big ,so i was thinking of reducing the collector size and going to a merge style is all It has a 3-1/2 in collector now,so i was wondering if i go down to a 3" choke ,then back up to a 3-1/2" opening to the muffler would be ok,or if an even smaller choke size would work I was told that at my elevation and power level ,that a 2.75 "or so choke size would be sufficient PIPEMAX RECCOMENDS THIS 416ci from 5450 to 7950rpm Diameter=1.933" to 2.058" Length=26.9 to 29.1" --------2 step primary pipe specs-------- 1st-1.933" length-13.5-14.6"long 2nd-2.058" length-13.5-14.6" long --------3 step primary pipe specs-------- first step is the same as above first step 2nd-2.058" length-6.7-7.3" length 3rd-2.183" length-6.7-7.3" length ---------collector-------- Diameter-3.525" - 3.775" length- 15.1" -------megaphone------- 3.025" taper to 4.025" 15.1" long Best HP & Torque 26.9" length primary Any opinions on this? Thanks |
Liked 3,246 Times in 987 Posts
I started to do some flow analysis when considering going to a merge collector but then called Mark Lelchook and was very happy with the results. Mark's expertise and workmanship is outstanding.
http://www.perfweldheaders.com/
Im sure he knows more on the subject than i would forget,unfortunatly ill be the one building these as for the money they get,i could build a few sets myself and possibly learn something in the process(although im not very trainable lol)
thanks though |
