Old 04-03-2013, 10:47 AM   #1
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Default Holley spread bore carb.
Are these carb.'s any good for a performance motor a friend has about 7 of them and i was thinking about buying them.I have a cleveland iron intake i wanted to put one on.
astikhossw is offline   Reply With Quote
Old 04-03-2013, 01:18 PM   #2
Jeff Lee
Jeff Lee's Avatar
Default Re: Holley spread bore carb.
Why wouldn't they be? It's a Holley so all Holley tuning tricks & parts apply. The rear metering plate can be replaced with a metering block, the vacuum secondary springs can be changed, jets can be changed, cams, etc., all in the name of tuning for performance or mileage.
Jeff Lee 7494 D/S '70 AMX
Old 04-03-2013, 06:15 PM   #3
jims5600
Liked 21 Times in 9 Posts
Jeff is spot on,take his advise
jims5600 is offline   Reply With Quote
Old 04-03-2013, 07:11 PM   #4
Jeff Lee
Jeff Lee's Avatar
I'm not sure the Holley spread bore is a direct bolt-on for a 351C factory Autolite 4bbl intake. I think it needs an adapter. Been a while since I've messed with 351's....
Old 04-04-2013, 03:13 AM   #5
bad440
bad440's Avatar
thinking 73s were spreadbore intakes...
bad440 is offline   Reply With Quote
Old 04-04-2013, 03:30 AM   #6
Jeff Lee
Jeff Lee's Avatar
I know the 1973 and newer Autolite is a spreadbore but I'm pretty sure the bolt pattern for the four studs is something weird. But there are adaptors available.
