Old 02-20-2013, 09:14 PM   #1
Richard Grant
Richard Grant's Avatar
Liked 13 Times in 7 Posts
Default LT1 Problem Starting
One of the reasons that I am considering switching to the LS1 is a problem I have with the LT1. When I try to start the car, it will not start until the third try. Every time you have to grind the engine, stop, grind the engine, stop and on the third try it starts and runs fine. You guys got any suggestions about what could cause this?
Richard Grant 4988 STK
Richard Grant is offline   Reply With Quote
Old 02-20-2013, 09:47 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: LT1 Problem Starting
Is it a street car? Stock Eliminator car? Or SS car?
Ed Wright 4156 SS/JA
Old 02-20-2013, 10:00 PM   #3
Richard Grant
It's a street car. Ed, I know that you are very knowledgeable about LT1's. Hopefully you or someone on the form can help me find the problem. My race car is a '69 Camaro small block. It's much easier to find a problem with it. I have fought these problems with computer cars before and they can be weird.
Old 02-20-2013, 11:05 PM   #4
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
Install a fuel pressure gauge. With the engine running record fuel pressure, now turn off engine with key off and watch fuel pressure, it should hold at the same point. If not you may have a check valve in pump that is allowing fuel pressure to not stay charged in lines. It probably will require the fuel pump to be replaced.
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 02-21-2013, 08:06 AM   #5
joelster
x2
There is a small schrader valve on the driverside fuel rail. It should go over 40lbs when you first turn the key to ignition. You should also be able to hear the fuel pump when you first turn the key on. It will prime for 3 seconds, and make a humming sound.
joelster is offline   Reply With Quote
Old 02-21-2013, 09:17 AM   #6
countrypuppy4865
countrypuppy4865's Avatar
Liked 229 Times in 71 Posts
X3 sounds like its slow getting its fuel prime. Try this before a first crank, open the throttle body and pour a little bit gas in the intake. If it cranks up first try this tells you it's a fuel delivery problem (fuel filter or pump more than likely.)
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 02-21-2013, 11:18 AM   #7
Richard Grant
I knew you guys would have some good suggestions, thanks. I will change the fuel pump and go from there. The car has 120,000 miles and would need a new pump soon anyway.
