Old 02-07-2013, 01:58 AM   #1
Chris Hill
Liked 244 Times in 26 Posts
Default How a Cal-track works
On a very basic level, does a cal-track work like a four link once the lash is removed from the system at the spring eye mount?
The bottom bar of the cal track is same as bottom bar of four link.
Leaf spring would be the top bar of the four link?
Chris Hill
Old 02-07-2013, 05:56 PM   #2
philbilly
philbilly's Avatar
Default Re: How a Cal-track works
Rumor has it money maker racing will help on the set up? I dont know. I installed the split mono and the cal tracs but I feel i am in nuetral position. I am curious how they work in terms that my dumb butt can understand. I have seen 0 difference in the way my car works. I had a 383 going 6.50s with 1.35 60 s when I made the swap. Since then I got my 283 in and have never did any adjusting.
philbilly is offline   Reply With Quote
Old 02-07-2013, 06:07 PM   #3
Liked 5,138 Times in 1,961 Posts
I would say it works more like a ladder bar, and the back half of the spring is the suspension
Old 02-07-2013, 06:26 PM   #4
Jeff Lee
Jeff Lee's Avatar
Ladder bar. Back half of spring only holds the car up. Shocks are suspension.
Jeff Lee 7494 D/S '70 AMX
Old 02-08-2013, 01:39 PM   #5
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Shocks dampen movement .
They have nothing to do with suspending the car.
Old 02-08-2013, 01:55 PM   #6
Rich Biebel
Rich Biebel's Avatar
Liked 549 Times in 215 Posts
Tom is correct...
Remove your shocks and the car's body will not do a thing....It's still "suspended".....unless you have a coil over shock....
Cal tracks work well but they are not much different than a ladder bar with a front mount that pivots.
Rich Biebel
S/C 1479
Stock 147R
Rich Biebel is online now   Reply With Quote
Old 02-08-2013, 02:34 PM   #7
larrylomascolo
Liked 77 Times in 31 Posts
What would be the equivalent of a cal-trac in a GM A body car ,the lakewood bar with the smaller upper bar with hiem ends at both ends that bolts to housing bracket,are they any good ?
Old 02-08-2013, 02:34 PM   #8
Monte Howard
Monte Howard's Avatar
Liked 71 Times in 23 Posts
Philbilly, I have. 67 camaro sbc E/SA car with caltracs. What I found best for basically our low hp Stockers are the lightest mono leaf spring you can get on the car that will just barely hold the car up. Then use the shocks to control rear suspension.Split mono's are probably to stiff for your car. Try to find a 175lb mono spring.
Monte Howard 3209 STK, 3208 SS
Monte Howard is offline   Reply With Quote
Old 02-08-2013, 04:21 PM   #9
Jeff Lee
Jeff Lee's Avatar
And that's what I meant without getting into the action of the shock. The rear of the springs does "suspend" the rear of the car. The "suspension" as I called it is the act of controlling the movement of the rear of the car suspended by a leaf spring in this case.
Old 02-08-2013, 10:40 PM   #10
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
you really cant say that its compared to a ladder bar ,or even a slapper bar ,,, it works more like a canter lever ,,,as the power is applied to the drive shaft the rear begins to rotate, at that point the lever action is moved to the pivot bell crank of the cal track witch loads the front of the spring where flexing takes place the most ,, even cars with big horse power the body has minimal separation from the tire ,,,it gives the rear a chance to rotate and hit the tire with out the shock of a slapper bar,not as solid as a ladder bar ,,, great design in my opinion ,, I am used to making my own stuff but ,it works gmonde
