Old 04-15-2007, 01:44 AM   #1
Adger Smith
Liked 880 Times in 311 Posts
Default Garage clean out
Intakes
1- Brodix New BBC tall deck, port matched by Brodix, fits Dominator Carb. $375
2-Brodix BBC for 4150 carb or Rons injection, tall deck, red powder coated and drilled for NOS or injection, ported. dyno time, $375
3- Weiand BBC Tunnel Ram Manifold (9.780 deck) W/2 refreshed 750 holley carbs, Bassett S/Steel Scoop & cover. No linkage. $950
4- 8 BBC dimple rods 7/16 NEW ARP bolts, Fresh resized, still press fit . $375
5- NEW Crankshaft, Eagle, BBC 4.25 stroke 2.200 journal, external balance $525
6. New Eagle 3.25 stroke Large main 2.100 rod SB Chevy steel crank $375
7- Pistons, JE Hi-Comp. 18deg SBC chevy, 1.420 comp ht. 4.002 bore, lite pins, notched for 2.180 IN. 1.625 EX. Dyno time, $250
8- 10 NEW BRC Pistons, lite weight, 4.125 bore, fit splayed valve heads, gas ported, notched for 2.20 IN. 1.625 EX. Dome Unshaped, for use in 358 PS/T engine or splayed valve V-6 $375
9- Comp Cams, Mopar, NOS roller cam,CRB/324-8/344-3-R114 286/304 Lift with 1.5 rocker ratio .750-.705 Dyno time only $200
10- Lunati SBC or Buick Splayed Valve Heads, RR-288-294E Roller cam
W/1.6 rockers 715-643 Dyno time $175
11- Comp Cams SBC Roller Cam 324-6-334-3 R-12 680-600 275-290 112deg
Dyno time, $150
12- Dana 60 4.88 Gears Used $75
13- 1.76 Powerglide Roller Bering case freshened after low time use. Turbo input, Alum.Hi Drum, Steel hub,New seals and clutches, manual shift valvebody, no trans brake, built for footbrake classes. $650
14. NEW Edelbrock Victor Jr SB Ford heads. Ported by Brodix full port & polish 66 CC chambers, no springs.
Excellent flow. Ex ports flow 80% & are opened up for NOS. $2,000
You can call me at 903-794-7223 or email me at adgersperf@aol.com
We can send pix of what you are interested in. ALL PRICES EXCLUDE FREIGHT
Payment in the form of Postal Money Order will get your parts shipped fed-ex the day we receive it. I have too many other used parts in the shop to list, e-mail me your "want" list.
Adger Smith
Adger Smith (Former SS)
Search this Thread:
Advanced Search
