Old 04-07-2007, 02:09 PM   #1
Ron Miller
Liked 13 Times in 7 Posts
Default Fuel Pump
Product Engineering Fuel System's
Combo 460 Racing fuel pump kit: PE 4805
1 ea. PE 4450 Combo Racing Fuel Pump, CNC Billet Aluminum body
1 ea. relay harness-PE 1050, 1 ea. inlet fitting #12 AN x 12 ST, 1 ea. outlet fitting #10 AN x 12 ST, you're choice of mounting bracket, 460+ Gallons per hour,supports up to 2000 H.P., Adjustable up to 43 PSI, Ext -8 AN bypass (Adj), Cleanable filter, Alcohol Compatible, Works w/ 12 & 16 volt systems, 7 vane imp, -12 AN boss O-ring in/out ports, Continuous duty pump dose not need a step down box,
4-Port Fuel Regulator with Bypass System: PE 9050-4P
For Carburetors and Nitrous Systems, Adjust from 3 - 12 PSI, fittings included are, #10 inlet, has 2 #8 outlets for carb and 2 #6 outlets that can used to feed Nos or a second carb, Stainless steel needle/seat assy, CNC Billet Aluminum body,
Combo kit with 4-Port Regulator By-Pass kit, all the AN-O-ring fittings, choice of mounting bracket, would cost over $1,000.00.
Sell for $900.00 plus shipping
Thanks for looking
Ron Miller
Brownstown, Mi 48134
734-782-9333 before 9:00 pm
Ron Miller
3287 GT/DA 92 Camaro
Ron Miller is offline   Reply With Quote
Old 05-04-2007, 03:03 PM   #2
Ron Miller
Default
Still for sale
Ron Miller
Search this Thread:
Advanced Search
