Old 09-10-2012, 12:03 PM   #1
SST159
Liked 20 Times in 16 Posts
Default Hood Scoop issues
Anyone out there experience issues with air flow on hood scoops?
I changed my hood and scoop last fall and have been experiencing the motor popping during the run ever since.
Sometimes it occurs just on top end in the traps and sometimes at randam during the run. I pulled valve springs and they are good, plug wires are good, changed carb, changed fuel system (planned on doing that anyway). At one point I made a carb pan that sealed of most of the air with foam to the top of the scoop. That made improvements but still pops at random.
I tried taking the pan off totally and made a pass which it broke up so bad I had to abort the run. That tells me this issue pertains to the hood scoop and the way the air is hitting the carb. The only thing I did not try yet was an air filter which I would rather not use if I can avoid it. Any input or suggestions before I lose the rest of my hair?
Thanks in advance for your help.
Drew Wonderly
SST 159
SST159 is offline   Reply With Quote
Old 09-10-2012, 02:01 PM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: Hood Scoop issues
sounds like its running out of air
Old 09-10-2012, 02:43 PM   #3
Mark Schmidt
Mark Schmidt's Avatar
It's definitely going lean. If you don't have a computer, click it in the lights and pull a plug on the return road and richen it up if needed. A scoop makes a world of difference to a carburator.
MDS Motorsports
Mark Schmidt is offline   Reply With Quote
Old 09-10-2012, 03:11 PM   #4
Dave Steltz
Dave Steltz's Avatar
Drew, with the Roadster I had some issues like this , especially when I went to the injection, go spend some money cheap guy, and get a UNI Filter...It made no change in power , but with straightening out the air flow made a world of difference...actually picked up a little MPH, vs air pans etc...
Same one that Ken and Tim run, check them out...
http://www.unifilter.com/online%20ca...utomotive.html
Dave Steltz 135G SG/SP/SST
BIAECH Racing Team
Dave Steltz is offline   Reply With Quote
Old 09-10-2012, 05:39 PM   #5
SST159
I did not pull the plug deal because the EGT has been around 1350 which is not bad for my motor. I have gone up about 4 jet sizes over this race season and find no difference in performance. Perhaps I have gone the wrong way however the EGT was up in the 1400's until I increased the jet sizes.
Dave, (Dave Whoooo) I did look at Kenny's unifilter and actually thought the same thing but did not want to scar my cheap reputation and spend 170.00 on something that does not work. All kidding aside I am seriously thinking on buying one. Even if it does not fix the problem it cannot hurt to have an air filter. What I should do is make a pass without the hood on and see what that does.
Drew Wonderly
SST 159
Old 09-10-2012, 05:49 PM   #6
nickh
nickh's Avatar
Liked 642 Times in 192 Posts
Drew check your PM I am a UNI Dealer have them in stock. Questions call me 832-264-2478
Old 09-11-2012, 07:58 PM   #7
Ed Sroka
I've performed CFD analysis on several scoop designs. Many with marginal results.
If you send me the details of the scoop, its position relative to the body/cage and let me know which scoop tray and carburetor you're using, I may be able to offer some feedback.
There are many concerns that exist here. It's likely a few scoop designs can cost in excess of 40 usable horsepower. The concerns with pressure and velocity begin externally and are exacerbated at the point of carburetor entry.
You can send a PM if you like.
I can provide information on the proper air filter choice as well.
Ed Sroka is offline   Reply With Quote
Old 09-12-2012, 11:04 PM   #8
SST159
Ed,
Thanks for the help.
I will PM you with some info as soon as I can.
Thanks.
Drew Wonderly
SST 159
Old 09-17-2012, 03:04 PM   #9
jmarkaudio
Try tying the vents together like the picture in the link. If the scoop upset the pressure at the bowl vents it can send it lean.
http://i287.photobucket.com/albums/l...udio/Flute.jpg
jmarkaudio is offline   Reply With Quote
