Old 05-13-2012, 01:43 AM   #1
SStockDart
SStockDart's Avatar
Liked 574 Times in 212 Posts
Default Best place to set record
It seems that the "value of national records" has diminished over the years. .I am just curious where might be the best place to set a record... Setting the national record is still a "big deal" to me (guess that is because I'm old LOL) It used to be Tucson (switched to IHRA) and Boise....also a bunch set in Kearney, NE...ATCO is wicked fast...Sonoma might be the place..."No Problem" is fast....Pomona is down hill...but National events only ..what do you think??? (For conversation purposes).
Old 05-13-2012, 05:35 AM   #2
jmcarter
jmcarter's Avatar
Liked 3,227 Times in 981 Posts
Default Re: Best place to set record
Mission can be fast but with a May date for the D6 race it's very dependent on weather...witnessed the first 7sec. SS run there and Hemi cars use to flock to that race to put up a good number.
Valdosta has been the site of many records, SS/AH and many others. Also, any of the early D2 races can be fast when temp and unbelievable barometer readings show up.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 05-13-2012, 08:51 AM   #3
Jason
Liked 6 Times in 4 Posts
The best place to set a record is at a national open. Your et will not effect the AHFS unless you go 1.20 or more under.
Jason is offline   Reply With Quote
Old 05-13-2012, 09:40 AM   #4
Talking Re: Best place to set record
Great thought ..........Maybe that fact will once again make records important to more than just a few of us "old timers " .................
Old 05-13-2012, 10:29 AM   #5
stefan callender
stefan callender's Avatar
Liked 2 Times in 2 Posts
I agree Jack, I cannot understand the NHRA's thinking. They should give back the 3 tenths on the indexes, and set the limit higher for the trigger point. Why cant everyone just show what they got if they want without getting penalized? As usual, its the crybabies that get what they want.
I especially dont understand the reasoning why there is such a large trigger at a National Event. I would think that the spectators in the stands that could relate to cars that look "normal" would like to see the true potential of stock and super stock cars.
Old 05-13-2012, 12:09 PM   #6
Stephen & Horace Johnson
Liked 163 Times in 53 Posts
Valdosta in November
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 05-13-2012, 06:08 PM   #7
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
They should take a different tact on it... you should get points and contingency for getting HP! Honey vs vinegar. It's strange to me how in this "performance" eliminator that often when someone goes fast, they get berated on this board. Which is it? To go fast or not to go fast? As a corollary, so many exclaim "performance!", yet find excuses to avoid any changes to class structures that might result in more heads-up runs.
Best place to set a record? How about Bristol? Then you can open it up a little more without feeling too guilty.
Old 05-14-2012, 01:15 PM   #8
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Smile Re: Best place to set record
For style points, do it like Jack......at Lebanon Valley in 95 degree heat.....
Eric Merryfield 1883 STK
Old 05-14-2012, 01:31 PM   #9
Greg Gay
Liked 286 Times in 73 Posts
Good job, Jack. And don't forget, Dave Casey did it with his Camaro, as well.
Greg Gay is offline   Reply With Quote
Old 05-14-2012, 03:31 PM   #10
Thanks Eric - Yep , style isn't a bad thing .................
