Old 04-26-2012, 08:47 AM   #1
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Default 12 bolt yoke
Can you tell me what needs to be done to a 12 bolt OEM yoke to put a logger sensor on it?
Ron Gusack is offline   Reply With Quote
Old 04-26-2012, 10:18 AM   #2
440lebaron
Default Re: 12 bolt yoke
i think the only tone ring you can buy are for 9", i glued my magnets to the ujoint caps
440lebaron is offline   Reply With Quote
Old 04-26-2012, 10:35 AM   #3
Dion Hildebrandt
Dion Hildebrandt's Avatar
Get a mark williams yoke.....joking.On the stock one I removed the dust ring in front of the seal and had to do some minor grinding ,computech had the appropriate sensor ring and your off to the races
Dion Hildebrandt 6009 STK H/SA
Dion Hildebrandt is offline   Reply With Quote
Old 04-26-2012, 12:38 PM   #4
Ron Gusack
Ron Gusack's Avatar
Thanks for the info, I have a ring from Racepak and I would like to not have to take the yoke off the rear to install it.
Old 04-26-2012, 02:06 PM   #5
Dion Hildebrandt
if your careful you can do the modification to the yoke on the car ,I did it on the car for the same reasons
Old 04-26-2012, 04:21 PM   #6
Ron Gusack
Ron Gusack's Avatar
What did you use to grind? A sharp flat file, Dremel, or a die grinder maybe? I'm thinking I have to pretty precise to keep the collar true.
