Old 01-07-2012, 11:19 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1966-69 BBC 396 & 427 Parts
1966 3869942 block 427 4 bolt standard bore E-17-6 with original pistons & rods $4000
1967 3919840 square port heads ported and rebuilt E-24-7 & F-7-7 $2000
1967 3919840 square port heads rebuilt E-18-7 & E-23-7 $2500
1968 3919840 square port heads both dated L-12-7 bare $1250
1968 3919840 square port heads dated L-21-7 & D-23-8 bare & ported $900
1968 3919840 single square port head dated E-8-8 $650
1969 3919840 square port heads rebuilt both dated B-20-9 $1750
1969 3919840 square port heads both dated A-22-9 bare $1250
1969 3955272 396 4 bolt block all machined 30 over dated J-8-8 $1750
1969 3955270 427 4 bolt block 30 over dated H-26-8 $4000
1969 8 inch harmonic balancer and 8 inch timing cover $150 each
1969 427 oil pan off of 435HP corvette block $150
6223 steel crankshaft turned 20 ready to go $300
6223 steel crankshaft standard balanced to new keith black 9.5 to 1 closed chamber pistons mounted on stock GM rods $600
1968 3933163 aluminum square port intake 3-20-68 with small weld repair on topside $300
1967 3855069 aluminum square port intake 6-27-67 with center plenum removed $300
#964 4 bolt caps and bolts for a 396 427 or 454 block $175
BBC NOS studs still in GM box $50
627990 square port heads complete $750
Edelbrock Tarantulla style square port intake $100
Spin on oil filter off of early 396 or 427 block $25
7/16 dimple rods compelte set of 8 $250
All parts cleaned and magged and intakes are both cleaned up ready to bolt on. I can ship any of these parts if you cannot pick up and can provide pictures with an email address. I can be reached at 330-770-2517 with any questions.
dlv4540 is offline   Reply With Quote
Search this Thread:
Advanced Search
