Old 12-18-2011, 09:19 PM   #1
Racer4077
Default Shift on time or RPM
I would like to know peoples thoughts on shifting on the throttle stop. I have my TS coming on .200 after the hit...on for 2.500 (give or take). I have tried both shifting on RPM and time. I have been more consistant by shifting at RPM, but run a little more MPH on time shift. So I wanted to see what you guys are doing and what works.
Racer4077 is offline   Reply With Quote
Old 12-18-2011, 11:19 PM   #2
Chris Williams
Chris Williams's Avatar
Default Re: Shift on time or RPM
I'm in the time camp. Way more consistent for me. Car climbs when on the stop otherwise. But YMMV.
Chris Williams 6304 SC, TD, ET
Chris Williams is offline   Reply With Quote
Old 12-19-2011, 01:34 AM   #3
Mickey Whaley
Time is Time does it change? Stick to time unless u blow the tires off
Mickey Whaley is offline   Reply With Quote
Old 12-19-2011, 09:02 PM   #4
Racer4077
if my stop comes on @ .2....when do i shift? I'm on the stop for 2.5....
I've set it before at .7, but was thinking its too quick. any thoughts?
Old 12-19-2011, 10:32 PM   #5
Chuck Westcott
Chuck Westcott's Avatar
Smile Re: Shift on time or RPM
.2 on the stop is a good hit !
.80 on the shift is good for me with a stop RPM @ 4200 puts me close to a .90 run @ 165 or so in S/Gas Trim.
Your Stop RPM is important to be consistant if you running S/Gas or S/Comp.Alway's check stop RPM at every track !
Chuck Westcott- S/C -S/G 225
Chuck Westcott is offline   Reply With Quote
Old 12-20-2011, 01:05 PM   #6
Racer4077
Thanks for the info. Chuck. Sounds good to me. I will try it. I have another question for you if you don't mind. If my stall RPM is 5600, what should my on the stop RPM be? I was told to set it at 500 RPM lower than my stall, but I have had problems doing that and running a consistant number.
