Old 12-03-2011, 06:42 PM   #1
Mike Savelle
Liked 7 Times in 5 Posts
Question is something wrong with this picture
2010 Mustang ---- 67 Camaro
2.08/160 valves 194/150 valves
5.12/5.12 cam lift 3.90/410 cam lift
roller cam hyd. flat cam
1.62 rockers 1.50 rockers
56cc heads 62cc
fuel injected Qjet
not sure on pushrods ??
NHRA/ 295 hp NHRA/290 hp
both run E/SA
Mike Savelle is offline   Reply With Quote
Old 12-03-2011, 07:08 PM   #2
SSGN
SSGN's Avatar
Liked 202 Times in 52 Posts
Talking Re: is something wrong with this picture
Nope perfectly normal ,did you not click the NOS bottle factory installed on the Camaro???I saw them on paper LOL
Kevin
Old 12-03-2011, 07:29 PM   #3
Maverick
Liked 36 Times in 26 Posts
Default Re: is something wrong with this picture
I got a question about the ford cam lift. Is this on the pushrod side? Or is this a SOHC/DOHC? If it has pushrods, that means the theoretical valve lift would be .829 inches. Am I seeing some thing the wrong way. THAT IS A LOT OF VALVE LIFT TO ME.
Old 12-03-2011, 08:27 PM   #4
eddie c
What is the difference in the cubic inches of the engines?
ed
eddie c is offline   Reply With Quote
Old 12-03-2011, 08:47 PM   #5
Andrew Hill
Andrew Hill's Avatar
Liked 174 Times in 39 Posts
ed
2010 Mustang- 352
1967 Camaro- 350
You forgot the mustang's better heads, intake, and throttle body as well. It has the potential for 9 second runs.
3207 D/SA, C/ED
Andrew Hill is offline   Reply With Quote
Old 12-03-2011, 09:14 PM   #6
eddie c
Smile Re: is something wrong with this picture
Originally Posted by Andrew Hill View Post
2010 Mustang- 352
1967 Camaro- 350
No, I wasn't making light of the situation. I was un sure of the Fords
engine size. I thought it might have been a 4.7 liter motor. I have been out of competition for several years,but there were many similarities
between then and now. Unfortunately the small block Chevy has been
raced and developed over several years,so currently, the Chevy is much closer to its full potential then the Ford.If someone races this Ford
combination next season and gets everything right,hopefully NHRA
will re factor the motor.
Old 12-03-2011, 11:54 PM   #7
Andrew Hill
I meant the last part as an addition to the original post.
3207 D/SA, C/ED
