Old 11-14-2011, 08:45 PM   #1
joe huestis
Liked 411 Times in 114 Posts
Thumbs up Proper Fuel Cell Winter Storage
Put a fuel cell in my stocker this season and was wondering what is protocol for winter storage. Should I drain it completely or ??? Plastic cell with foam inside. Thanks for any tips. - Joe
Joe Huestis
Youngsville, NC
Old 11-14-2011, 08:47 PM   #2
Chad Rhodes
Default Re: Proper Fuel Cell Winter Storage
first step is to get the foam out before it clogs something up. then just drain it
Chad Rhodes 2113 I/SA
Old 11-14-2011, 09:04 PM   #3
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: Proper Fuel Cell Winter Storage
X2, get that foam out pronto! Jim
Old 11-14-2011, 11:35 PM   #4
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Not to hijack this thread but the replies prompted me to ask the question since a fuel cell is the winter project on my car.
Is removing the foam just part of the winter draining process, or should the foam not be used on a drag car?
Thanks
Chad
Chad E532 is offline   Reply With Quote
Old 11-15-2011, 12:39 AM   #5
Dion Hildebrandt
Dion Hildebrandt's Avatar
Thanks
Chad
Do NOT use the foam ,......unless you enjoy headaches. It breaks down and will plug everything.
Dion Hildebrandt 6009 STK H/SA
Dion Hildebrandt is offline   Reply With Quote
Old 11-15-2011, 09:39 AM   #6
Chris DeGidio
Chris DeGidio's Avatar
Liked 2 Times in 2 Posts
Pulled the foam out after replacing pump,going thru carb and regulator and flushing lines etc.Not worth the hassle or $$$ it cost me.
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
Old 11-15-2011, 10:53 AM   #7
Chad Rhodes
It can also make you fail fuel check if you switch fuels.
Old 11-15-2011, 11:15 AM   #8
Rusty Davenport
Liked 101 Times in 27 Posts
Put the Marvel Mystery Oil In......let the engine run for a while.........forget it.
Rusty Davenport is offline   Reply With Quote
Old 11-18-2011, 02:59 PM   #9
Bill Pomponi
Question Re: Proper Fuel Cell Winter Storage
There appears to be very strong opinions on both ways........foam in and foam out. C'mon guys........Which is it?
We've left the foam in w/o any problems
Definitely run Marvel Mystery throught the entire fuel system........cell to carb. I'm sure everyone has witnessed residue from racing fuels especially VP !
Bill Pomponi is offline   Reply With Quote
Old 11-19-2011, 02:01 PM   #10
Mike Croley
Foam in , there's really no debate on the subject . It serves a very important function .
As to foam deteriorating , there are several reasons that it might . One , the foam in race fuel cells is not exactly the same foam as you find at the local Home Depot . Foam not designated for fuel won't work , at least not for very long .
Another reason for foam deteriorating is mixing of fuels . Gasoline requires one type of foam . Alcohol fuels , including E fuels will require a different foam . Some manufacturers may have a foam that they feel is compatible with all types of fuel . Ask their opinion . And sunlight harms the foam , so don't take it out of the cell and leave it on the work bench over the winter .
Mike Croley is offline   Reply With Quote
