Old 12-08-2006, 12:54 AM   #1
mishsc
Default 1969 SS CAMARO PRO BRACKET CAR
'69 SS CAMARO,BLUE W/WHITE SS STRIPES.LASER STRAIGHT,ALL STEEL BODY.BODY WAS DIPPED AND BLASTED BEFORE PAINTING.NEW GRILL,NEW REAR BUMPER,NEW SS EMBLEMS.ALL NEW BLACK FACTORY INTERIOR(LOOKS ORINGINAL MINUS BACK SEAT)ALL GLASS(NO LEXAN),CHEETAH SHIFTER,AUTOMETER MONSTER TACH W/SHIFTLIGHT.8POINT ROLLCAGE.PAINLESS WIRING W/8SWITCH CONTROL PANEL.LEAF SPRING CAR W/COMPITITION ENGINEERING SLIDE-A-LINK BARS.NEW QA-1 6-WAY ADJUSTABLE SHOCKS ON REAR,COMPITITION ENGINEERING SHOCKS ON FRONT.8 GAL. FUEL CELL W/NEW BARRY GRANT PUMP,FILTER,AND REGULATOR.2 NEW GEL FILLED BATTERIES MOUNTED IN TRUNK.15X15 WELD WHEELS W/PHOENIX F/X SLICKS,15X3 1/2 WELDS W/MICKEY THOMPSON E.T. FRONTS.427 4-BOLT MAIN .60 OVER,VENOLIA SUPERSTOCK PISTONS,EAGLE H-BEAM RODS,STEEL CRANK,BULLET CAM,JESEL BELT DRIVE,BRODIX ALUMINUM HEADS W/STAINLESS STEEL VALVES,BRONZE GUIDES,COMP CAMS TRIPLE VALVE SPRINGS W/TITAINIUM RETAINERS,CRANE GOLD ROLLER ROCKERS,REHER-MORRISON STUD GIRDLES AND ALUMINUM VALVE COVERS.EDELBROCK ALUMINUM INTAKE W/HOLLEY 1050 DOMINATOR CARB.SHORTBLOCK IS A LEGAL SS/DA SHORTBLOCK BUILT BY SCHINDLER RACING ENGINES,MSD BILLET DISTRIBUTER W/7AL2 IGNITION BOX AND 2 STEP.2 SPD. POWERGLIDE W/TRANSBRAKE AND SHIELD,DONE BY COAN IN JULY OF 2005,COAN 5500 STALL CONVERTER(NEW FROM COAN IN 2005)AND NEW 4IN. ALUMINUM DRIVESHAFT W/BIG U-JOINTS AND MOSER BILLET YOKES.9IN. FORD W/NODULAR CASE,STRANGE SPOOL AND MOSER AXLES WITH 1/2IN. STUDS.NEW 4.86 RICHMOND PRO GEARS.NEW STRANGE 4-WHEEL DISC BRAKESAND MASTER CYLINDER AND LINELOCK.ABSOLUTELY NO EXPENSE SPARED AND NO CORNERS CUTON THIS CAR.CAR LEAVES HARD AND GOES STRAIGHT.BEST E.T.6.38 @108,1.41 60FT.(1/8TH MI)WITH 325LBS. DRIVER.THIS CAR IS SUPER CLEAN,MANY COMPLIMENTS AT THE TRACK.NO JUNK AND NO DISAPPOINTMENTS HERE.PICS CAN BE SEEN ON RACINGJUNK.COM,AD#779290.LET ME KNOW IF YOU HAVE ANY QUESTIONS AND THANKS FOR LOOKING.LOCATED IN FLOYDS KNOBS IN. $39,000 COMPLETE TURN KEY WITH FRESH MOTOR $32,000 LESS MOTOR $29,000 ROLLING...(502)727-9909 CELL...OR mishsc@aol.com
mishsc is offline   Reply With Quote
Search this Thread:
Advanced Search
