Old 09-13-2011, 05:28 PM   #1
ChevyII
ChevyII's Avatar
Liked 2 Times in 2 Posts
Default Fuel Line covering to reduce heat
What are you guys/gals using to prevent heat buildup near fuel lines? What are you using to cover fuel lines?
Your help would be appreciated.
Mike
ChevyII is offline   Reply With Quote
Old 09-13-2011, 09:57 PM   #2
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Default Re: Fuel Line covering to reduce heat
I've been using the poly insulation you can buy at the home improvement big box stores, looks like rollbar padding but smaller. It's pre-split, conforms to the fuel lines easily, and I can cover it with duct tape to keep it in place.
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 09-13-2011, 10:14 PM   #3
Chad Rhodes
Lew
i wouldn't route that near anything hot
Chad Rhodes 2113 I/SA
Old 09-13-2011, 10:51 PM   #4
Lew Silverman
I guess I should explain that I'm still using a mechanical pump, so the line from there to the regulator and carb aren't that close to headers.
Sorry for any confusion!
Lew
Lew Silverman #2070
Old 09-14-2011, 10:30 AM   #5
55 Chevy
55 Chevy's Avatar
Liked 20 Times in 15 Posts
My neighbour is an insulator and he gave me a roll of asbestos that they use for wrapping high temperature pipes. It is sort of like split loom and I use stainless tyraps to hold it on. It has a coating on it so no fibres come off.
You can lay it right on a header and it is cool on the other side.
Allan
55 Chevy is offline   Reply With Quote
Old 09-14-2011, 01:16 PM   #6
Liked 5,153 Times in 1,967 Posts
Lew
Old 09-14-2011, 02:13 PM   #7
austin weidhaas
Liked 14 Times in 3 Posts
Thumbs down Re: Fuel Line covering to reduce heat
Apparently your neighbor hasn't been reading the news or watching t.v. the last decade or
so. Asbestos causes CANCER !!! Asbestos is illegal !!! GET RID OF YOUR NEIGHBOR HE'S DANGEROUS.
Austin Weidhaas 1368 STK
austin weidhaas is offline   Reply With Quote
