![]() i run slide a links, i just put 9 way caltrac shocks on it and it helped my 60' but it still spins bad. this video is last weekend there is 160lbs of weight in the car, 10psi of tire pressure. i dont know if i need stiff sidewall slicks, or more pre load or whats up. any help will be greatly appreciated.. |
![]() here is another video from a different track |
Liked 2 Times in 2 Posts
I just watched the first set of videos not the second but from what I saw you a have a couple things going on there. First would be to get more front end travel one way or another. Second would be to make the front react quicker, free it up some. Then in the rear, the body is rolling over on the passenger so there you have two things. First you need to get the car to leave straight. An air bag on the cheap side or a anti-roll bar to do it right. Along with that the rearend is not separating (planting the tire). This could be from the rearend being in a bind and/or the shocks set to stiff and/or way to much preload on the slide links. Hope that helps.
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
Liked 33 Times in 15 Posts
Work on the front suspension. Do a search on this site, it'll fix you right up.
Joe Marcinowski 3377 STK |
Video one looks as though the slicks needed a little more air. They wadded up pretty good and spun at the hit. The second looked to be slightly better. It actually rolled out and let loose about a foot / foot and a half out. Dont know if you changed something between those two passes. (now this was the first set of videos) There seems to be some binding in the rear suspension. There's no movement either way. (I personally don't know how those 'slide-a-links' work.) Only thing moving is the sidewall of the slick. I looked at the second set of videos and they all seemed fairly consistant. Low pressure and wadding up the tire.
Most importantly, don't go changin' a bunch of stuff at once. Ive seen many that do and all it does is lead to frustration. If I were to make a suggestion, I'd probably try going up with the pressure. If you're running 10 now, jump 'em up to say 11.5 and see what kind of pattern they're leaving. If they're still nice and flat and it helps on the line, you can bump 'em up a little more. Keep us updated on the changes you make and how the car responds.
Phil Hudlow 6678 (S/C, S/G, ET-PRO) |
Liked 19 Times in 7 Posts
It would be easy to say that you could put a few turns of preload into the passenger side bar but im not sure that will work. Slide a links have a urethane bushing so maybe have a look and see of they are showing signs of wear and rebounding. Front suspention is where you will find the most help...make sure its loose and moves freely through its travel. I would check the front shocks out as well. If you have the factory rubber snubber in the upper front control ams take them out...that will give you some more front end travel. Do you still have rubber bushings in the front leaf spring eyes? If so change to a Moroso solid or just order a set of Calvert Split-Mono's and forget about it. I played with a set of old super stock springs for a year untill it started cork-screwing like your car is doing and then that was it....changed to the whole Calvert setup and never looked back. A comment was made about an Air Bag but thats gonna be tough in a leaf spring deal...ive never seen an air bag on a leaf spring car. Good luck and let us know how you make out.
Tony Valerio 1968 Camaro 1700 IHRA H/CM 1701 NHRA SS/?A |
