Hey guys,
I tracked down a set of free wheeling tow hubs. I will buy a tow bar etc soon as well,, The only problem so far I am encountering is that I cannot use my emergency brakes. My c-clip eliminator block prevents me from using my parking brake. The "block" portion is too large to allow the brace to pass through the wheel cylinder - c-clip block opening. I tried to weld together a thinner piece for the brace but it does not seem to work.. So, I was wondering instead of putting it in neutral and applying the parking brake, can I just leave the trans in park when using the hubs? OR is it hard on the drive line?? Thanks, Kris
http://www.youtube.com/watch?v=h2qQX4TDTVU |
Liked 880 Times in 311 Posts
Put a line lock on the rear brakes. Some trucks use a brake lock system called Micro Brake, or Mico. It's nothing but a manual line lock.
http://www.awdirect.com/lever-lock-m...ake-locks-pto/
Adger Smith (Former SS) Last edited by Adger Smith; 06-15-2011 at 11:58 PM. Reason: Add link |
Thanks Adger, that is a good option.
I went to the u-pull it yard today and got a few extra emergency brake strut rods..I will try to grind them down to get some more clearance to try to get the e-brake system to work.. The problem is clearance between the c-clip eliminator block and wheel cylinder does not allow the strut rod brace to fit.. Does anyone have tips on flat towing?? Yes, I know it is not the best form of towing but I figure some of you guys did back in the day... KP
Yep, went all over the place with a home built tow bar and home built hubs. Seems like I have a picture of my Vette with the tow bar on the ground in front of it.
I learned to pull the driveshaft before using the hubs. I also found out the 4.56 gear lasted longer than 5.13's and 5.38's when towing without hubs. I think those small pinions just whipped the oil away at highway speeds. Stopped breaking the rear gears when I built the hubs. We were "up town" when we got our first homebuilt trailer. Tip for flat towing: Slow down....
Adger Smith (Former SS) Last edited by Adger Smith; 06-18-2011 at 06:30 PM. Reason: sp |
Thanks again! KP
Liked 8 Times in 7 Posts
if i understand correctly, you have some hubs that bolt on to your axles and then the wheels bolt to them, correct?
your e-brake will not have any effect on stopping UNLESS you have them attached to the outer hub/drum assy....think about it... and then go buy a trailer. with brakes on BOTH axles (93 and up is manditory) |
