Old 05-17-2011, 06:03 PM   #1
GHoef
Liked 9 Times in 2 Posts
Default 67-68 camaro parts needed (rearend - trans)
Just purchased a completely stock 68 camaro(fresh 250" straight 6 and T5, 5 speed) . I'm looking to ditch the 8.2 10 bolt the straight 6 and 5 speed in favor of either a 8.5" 10 bolt or 12 bolt, Th350 and a V8 (327-383) to complete the the project. Would like to have a low gear set th350 if possible.
also needed, caltracs split mono-leaf setup.
If you guys have any of this type stuff, please hit me up.
Ultimate goal to build toward being a stocker, which will not happen anytime soon =) ... Thanks
Garrett - (909) 844-0567
Last edited by GHoef; 05-17-2011 at 06:05 PM. Reason: did not include certain info and a misspelling
GHoef is offline   Reply With Quote
Old 05-19-2011, 09:32 AM   #2
Richard Grant
Richard Grant's Avatar
Liked 13 Times in 7 Posts
Default Re: 67-68 camaro parts needed (rearend - trans)
I believe that you must run the powerglide in '67-
'68 Canaro's. I have a B&M Mega shifter for the 350 if you can use it. I also have a 2.08 lite Powerglide if you must run it. Make sure if you run a 350 that you not only get the low gear but also the lite parts. Send me a PM if I can help with advice.
Richard Grant 4988 STK
Richard Grant is offline   Reply With Quote
Old 05-19-2011, 02:35 PM   #3
GHoef
Thank you, I was not aware of that.. learn something new everyday
Search this Thread:
Advanced Search
