I always assumed most of you guys ran methanol in your s/c diggers. while i was at the track today i noticed and smelled that almost all the s/c cars were running the oxygenated race fuel. i was planning on running methanol but now thinking otherwise. methanol makes more torque, cools well, less responsive to da changes, yet no one was running it really. is it a methanol engine maintenence issue? please clue me in, sorry for the newb question.
FWIW, I don't know anyone who runs on methanol.
Chris Williams 6304 SC, TD, ET |
Liked 888 Times in 239 Posts
Alcohol is for drinking!
Only a handfull of SG cars in D1 run methanol, mabe a few more in SC. Big inch .90 type motors dont seem to benefit as much from alcohol as do smaller motors, unless you run injection. A few racers are running Q16,but most are still running well with conventional racing gas. Last years top 4 in D1 SG, #1 reg race gas, # 2 oxygenate fuel,#3 methanol ,#4 reg race gas.
I run Alky. $130 for 55 gallons. Dragster uses 1.5 gallons 1/4 mile almost a gallon in the 1/8th. Camaro uses little over a half in the 1/4 and a little under a half in the 1/8th.
I change the oil at around 100 passes. Don't be scared of alky. A few suggestions would be. Call George Rupert and buy the entire setup including the Belt drive pump. Call Biondo and order a T-stop. I use the plate on both cars. Chip Johnson |
[QUOTE=THE LEGEND;256071]I run Alky. $130 for 55 gallons. Dragster uses 1.5 gallons 1/4 mile almost a gallon in the 1/8th. Camaro uses little over a half in the 1/4 and a little under a half in the 1/8th.
I change the oil at around 100 passes.Don't be scared of alky. I too run alky like the Legend said it's cheaper and more consistent I run a Rons fuel injection (A terminator) with a highspeed lean out.I also run a top oil with grape scent since it smells kinda nasty. I have a gas primer system, block and oil heaters to help with cold starts and quicker warm ups. I also run a vacuum pump. Tips: Keep the fuel tank full so the pump stays submerged, it doesn't color the plugs so trust the ET/MPH, if you go the F.I route you need to use an inline stop. with the F.I.It's a little harder to start than a carb but the trottle response is instantaneous.
Bill Baer 3391 SC, 339B SC, QR Last edited by Bill Baer; 05-01-2011 at 07:39 PM. |
i run allky never had a maintence issue ,like the way it runs ,legend said rupert (very good) i also run a quick fuel alcohol carb
jj h/r 1399 s/r 1399 ![]() |
