Old 03-30-2011, 03:06 AM   #1
DJ FARIAS
Default Cal Tracs
Hi I race a 69 Nova with 9'inch tires and a slaper bar setup..Question is my 60ft average is 1.58 would I gain anything better if I get a set of Cal Tracs is it worth the investment any input.
Thanks DJ
DJ FARIAS is offline   Reply With Quote
Old 03-30-2011, 08:21 AM   #2
cad
cad's Avatar
Liked 93 Times in 52 Posts
Default Re: Cal Tracs
It took us quite a while to make repeatable gains with just the Cal-Tracs. And when the track would change, we would get a hiccup.
After we bought the leaf springs the 60's were more predictable.
It really is a "system" in my opinion. Buy his rear shocks also...you do not need double adjustable shocks on a leaf spring car.
Calvert's front 90-10 shocks also helped free up the front some more.
Clark
Old 03-30-2011, 12:38 PM   #3
sprnova
sprnova's Avatar
not to take over the thread but what is the normal ride height everyone is using on a 69 or 70 model nova? 1 inch higher, level, or 1 inch lower. (split mono leaf style)
Josh Edwards 752A
SS/GM, SS/BX, I/SMA
sprnova is offline   Reply With Quote
Old 03-30-2011, 02:18 PM   #4
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
I use the one inch higher in mine for the ballast we have to carry.
68 Chevy11 327 F/S
Bob Gullett is online now   Reply With Quote
Old 03-30-2011, 03:41 PM   #5
Dana Fitzpatrick
Liked 10 Times in 6 Posts
DJ, I agree with Clark. If you switch, buy the split monos, bars and the shocks. I have had good results with their front shocks, as well. As to weather it would be worth it, are you having traction issues now?
Dana Fitzpatrick is offline   Reply With Quote
Old 03-30-2011, 04:09 PM   #6
gearjammer9025
We use the cal-tracks an 9-way adjustable shocks and the 90-10 on the front, all from Calvert Racing. On our 69 G/S Camaro. Running a 4 speed. Saw alot of improvment just with the cal-tracks. I would recommend using 10" rim with your tires if the will fit..... Usually a 1.53 60' times. Going to try the new shocks out this weekend.
gearjammer9025 is offline   Reply With Quote
Old 03-30-2011, 04:26 PM   #7
jim powers
jim powers's Avatar
Liked 13 Times in 10 Posts
the cal tracs are a great "system" as the others have said, the real issue will be just how good you have the car working with the present slapper bars, when i had my 69 camaro my slapper bars were home made and worked really well,what improvement you see will depend,i would recommend them in any case
jim powers is offline   Reply With Quote
Old 04-04-2011, 02:45 AM   #8
DJ FARIAS
Thank you all for your feed backs!
DJ
